Old 03-01-2024, 11:33 PM #1
JettyHopper JettyHopper is offline
JettyHopper is on a distinguished road
Long distance travels - Maintenance
Hey wanted to see what everyones doing BEFORE & AFTER LONG TRAVELS (1000 plus total miles) on your 5th gen!
Here's my checklist;
Before
- Tire wear
- Tire pressure
- Brake wear
- Engine Oil
- Diff oil
- Air filter
- Spare tire check
After
- Change my engine oil
- Change diff oil
- Air filter
- Check brake wear.
- Rotate tires
JettyHopper is offline   Reply With QuoteReply With Quote
Old 03-02-2024, 01:37 AM #2
Argyle Edison Argyle Edison is offline
Argyle Edison will become famous soon enough
Put gas in car. Drive
Argyle Edison is offline   Reply With QuoteReply With Quote
Old 03-02-2024, 08:16 AM #3
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
Before Check:
Tire pressure
Oil
Coolant
Battery terminals
Belt
PS fluid
Fill washer fluid
That's it. I know my diffs, T-case and trans are always full and clean and I always know the status of my brakes. I also grease driveshafts every other oil change. Filters are done every 20k or so. Spare gets checked yearly. I do nothing after the trip.
Sent from my SM-S901U using Tapatalk
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 03-02-2024, 10:55 AM #4
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Follow the maintenance schedule in the owners manual. If you are towing a trailer, driving at high speeds, or serious off road, use the severe service schedule.
If a needed service comes up while traveling, go to the local Toyota dealer and get it done; don't put it off.
fkheath is offline   Reply With QuoteReply With Quote
Old 03-02-2024, 01:16 PM #5
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
1,000 miles is far?
Sent from my SM-S908U using Tapatalk
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 03-02-2024, 09:24 PM #6
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
Our 4Runners are regularly going back and forth between Southern California and Montana homes, which is 1200+ miles each way. On average they’re doing this up to twice a month. We just follow regular maintenance.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 03-02-2024, 11:11 PM #7
Ezlife45 Ezlife45 is offline
Ezlife45 will become famous soon enough
Changing oil after a 1000 mile trip is a little excessive. Highway miles are about the easiest on the engine. And diffs are generally only oil. Follow regular maintenance as stated. If you're nervous and would exceed scheduled maintenance on the trip, pull it in early. I do mine every 5K and tranny every 50. Probably will let rear end go 100.
But hey, if it gives you peace of mind and you're doing the fluid changes instead of Bubba, then go for it.
Ezlife45 is offline   Reply With QuoteReply With Quote
Old 03-03-2024, 04:11 PM #8
4skrunner 4skrunner is offline
4skrunner will become famous soon enough 4skrunner will become famous soon enough
I usually just top off my tires and fill up on washer fluid. Maybe clean the inside out. I won’t do an oil change specifically for a road trip.
4skrunner is offline   Reply With QuoteReply With Quote
Old 03-05-2024, 12:06 PM #9
Greydog's Avatar
Greydog Greydog is offline
Greydog is on a distinguished road
Greydog's Avatar
Brakes: I would perhaps bleed the calipers to get some fresh fluid in, if not done in last 6 months.
Engine Oil: if close-ish to your interval, do it pre-trip.
Diffs: same as engine oil, if close c9nsider pre-trip. Kind of depends on how hard you’ll be using the truck for those 1k miles. Ideally you’ve already changed front and rear diff oil once already?
Trans: I do 40-50k drain and fills, I don’t consider it lifetime. Not flushes, just drain and fills.
Spare tire: yes check air, also test out that you can lower it, make sure the mechanism is not rusted in there.
Coolant: top off the expansion tank. If you have never drained the rad and block, perhaps drain those if it’s been in for a few years, just as good preventive maintenance, but not needed until 100k per Toyota. Personally, I do mine every 50k, with long term water pump and head gaskets in mind.
Light bulbs: check the external lights?
Wiper blades: old blades suck
Serpentine belt: if your over 100k, have you changed this yet? Might not hurt to do that now.
Hope that helps 👍
2019 TRD OffRoad - Fox w/Resi, 650lb Springs, JBA HD UCA, T12 Rear Springs w/DS 5mm Spacer, Odyssey 34R-PC1500T AGM w/Diode Upgrade and CTEK Monitor, NOCO battery charger wired to external port for shore power, Rago Hidden Winch Plate, Comeup Seal 9.5 RSI, RCI Sliders/ Skids, 285/70-17 Cooper AT3 XLT on Fuel Rims, Various LED upgrades, OE Engine Heater w/External Port, XenonDepot Low Beam HID & LED 3k Fogs, ScanGauge, Midland GMRS, Accessory Mount for iPad, mike and Inreach, iKamper Mini 3.0, Custom Kitchen/Cargo system, ARB 50Q, Goose Gear dual drawer, Wilco Solo Tire/Hilift/RotoPax Carrier.
Greydog is offline   Reply With QuoteReply With Quote
Old 03-05-2024, 08:26 PM #10
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
I drove 1000+ miles roundtrip last weekend. To go take a look at a car I might buy. 1000 miles isn't a big deal.
I'd check the tires for wear and pressure, but wouldn't worry about doing any major maintenance just for such a trip. If you're due for an oil change, sure do it beforehand if you want. Cruising down the highway are the easiest miles for any vehicle.
02SE is offline   Reply With QuoteReply With Quote
brake , long , oil , tire , wear
Heavy Long Distance Tow biglar 3rd gen T4Rs 4 05-17-2021 04:40 PM
Long distance help for a friend... Martinjmpr 4th Gen T4Rs 3 09-02-2015 01:19 PM
Towing long distance mireille 3rd gen T4Rs 3 02-14-2011 10:19 AM
Long distance towing TRBenj Gallery 14 02-06-2008 08:50 PM
towing long distance tomcp Classic T4Rs 4 01-12-2008 11:42 PM
