Old 04-23-2019, 03:10 PM #1
TOTAL CHAOS TOTAL CHAOS is offline
TOTAL CHAOS will become famous soon enough TOTAL CHAOS will become famous soon enough
NEW Expedition Series Lower Control Arms from TOTAL CHAOS
TOTAL CHAOS is proud to announce the release of the all-new EXPEDITION SERIES lower control arms. The Expedition Series is an evolution of the original Race Series which increases ground clearance and adds component strength. With strategic additions and subtle enhancements, the Expedition Series lower control arms will improve on and off road handling on a wide range of suspension configurations.
One of the main features of the Expedition Series lower arms are newly integrated steering stop tabs which retain factory turning angle with no modification necessary to the OEM ball joint cradles. Put that grinder away for this install, these are 100% bolt-on.
Only found on Expedition Series lowers, strategically placed pockets have been added at the coilover shock tabs to increase clearances allowing for a wider range of shocks to be used (up to 3.0").
Uniball cups on the Expedition Series lowers are part of a stout one-piece billet design that increases strength and provides more turning clearance. 1" 100% stainless steel uniballs are included which replace the factory ball joints.
As with all TOTAL CHAOS lower control arms, replaceable polyurethane pivot bushings and zerk fittings are included for easy maintenance. As always, don't forget to prep your sh*t!
TOTAL CHAOS Expedition Series lower control arms consist of laser cut 4130 chromoly throughout and are 100% MADE IN THE USA. Currently the Expedition Series is available as a stock length replacement. Single or dual shock variants are also available for vehicles with or without KDSS. Note: for dual shock applications, a 1.25" wheel spacer is required to keep the tire from hitting the second shock at full steering lock.
05+ Tacoma | 03+ 4Runner | 07+ FJ | GX470 & GX460 | Prado 120 & 150
SHOP EXPEDITION SERIES LOWER CONTROL ARMS
Looking for KDSS options? Click the links below
Expedition Series - KDSS Lower Control Arm - Single Shock
Expedition Series - KDSS Lower Control Arm - Dual Shock
TOTAL CHAOS
WWW.CHAOSFAB.COM
TOTAL CHAOS is offline   Reply With QuoteReply With Quote
Old 04-23-2019, 03:14 PM #2
dot_tom's Avatar
dot_tom dot_tom is offline
Real Name: Tom
dot_tom is a name known to all dot_tom is a name known to all dot_tom is a name known to all dot_tom is a name known to all dot_tom is a name known to all dot_tom is a name known to all
dot_tom's Avatar
Real Name: Tom
Great product!
2017 4Runner TRD OR - Progress Thread
295/70/17 BFG KM3, SCS F5 17x9 -38, Front 5100 Rear MT Icon, Dobinson 314 & 701V, Gobi Stealth, RSG Sliders, ECGS 4.56's, Demello Front bumper, Coastal Off Road Rear Bumper
IG: dot_tom
dot_tom is offline   Reply With QuoteReply With Quote
Old 04-23-2019, 08:09 PM #3
EddieV4runnin's Avatar
EddieV4runnin EddieV4runnin is offline
EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough
Are these compatible with shocks that have a rubber bushing at the lower rod end?
Mods are loading.......
EddieV4runnin is offline   Reply With QuoteReply With Quote
Old 04-24-2019, 12:50 PM #4
They sure are!
Strategically placed pockets have been added at the coilover shock tabs to increase clearances allowing for a wider range of shocks to be used (up to 3.0")
This allows customers to run a rubber bushing rod end shock (Factory, Billstein, Old Man Emu, Etc.) as well as a larger 3.0 shock like what King offers.
TOTAL CHAOS
TOTAL CHAOS FABRICATION
Old 04-25-2019, 03:11 PM #5
This means you can NOW install a bushing lower rod end shock or a 3.0!
Click the link below to find Expedition Series Lower Control Arms for your ride!
TOTAL CHAOS | Expedition Series LCA
TOTAL CHAOS
WWW.CHAOSFAB.COM
Old 04-30-2019, 07:50 PM #6
jasxn's Avatar
jasxn jasxn is offline
jasxn will become famous soon enough jasxn will become famous soon enough
jasxn's Avatar
@TOTAL CHAOS just to clarify, with the addition of your UCA and Expedition LCA I can order the Tundra 3.0 Kings and it would work fine with the 5th gen?
edit: I wonder if having KDSS wouldnt allow me to use the 3.0 Kings. Assuming since Kings have specific coilovers for 5th gens with kdss.
i got the stuff
jasxn is offline   Reply With QuoteReply With Quote
Old 04-30-2019, 10:09 PM #7
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
I got a silly question.
Can I run a single shock on a dual shock LCA with no problems?
Old 05-01-2019, 05:03 PM #8
Correct! 3.0s will work with the Expedition Series. We offer both KDSS and non-KDSS models. You can run the larger diameter shock with either
TOTAL CHAOS
Old 05-01-2019, 05:04 PM #9
Sure thing! You will have to run wheel spacers to clear the secondary shock tab
TOTAL CHAOS
Old 05-01-2019, 05:20 PM #10
GX4SEVEND's Avatar
GX4SEVEND GX4SEVEND is offline
GX4SEVEND has a spectacular aura about GX4SEVEND has a spectacular aura about
GX4SEVEND's Avatar
Really wish this would have been offered a month ago before I spent money on the race series. Literally one month.
Anyway...I run them without wheel spacers just fine. Turning radius suffers though. I’m running after market wheels though.
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
GX4SEVEND is offline   Reply With QuoteReply With Quote
Old 05-01-2019, 05:26 PM #11
REDDY_KILOW4TT REDDY_KILOW4TT is offline
REDDY_KILOW4TT is on a distinguished road
I doubt I could even scratch the surface on what these were designed to do.
REDDY_KILOW4TT is offline   Reply With QuoteReply With Quote
Old 05-06-2019, 07:47 PM #12
Overland Expo West is coming up!
We'll be in booths P11 / P21 near Baja Designs and SDHQ. Come check out our new project build with Expedition Series Lowers ;)
See you there!!!
Ways to Attend WEST — Overland Expo
TOTAL CHAOS
Old 05-07-2019, 12:52 AM #13
canadian bum canadian bum is offline
canadian bum will become famous soon enough
Does this use the same size uniball that you use in your upper control arms?
2016 ORP, OME 3" lift with 1/2" coil spacer, Modified Metal-Tech Bumper, 295/70R17 STT Pro, and a bunch of other stuff.
2005 Tacoma DCLB that is a bit ridiculous Build Thread
78 FJ45 and 79 BJ40 Land Cruiser never ending projects
IG @schultzy507
canadian bum is offline   Reply With QuoteReply With Quote
Old 05-07-2019, 01:15 AM #14
I felt the same when i added aftermarket LCA's to my titan. But daily driving i noticed a better ride, increased responsiveness, tighter steering feeling, etc. Using products that don't bind, offer less or zero deflection, and look amazing really helps justify the cost especially when you notice it every day. Even if you don't abuse it like these were meant for. Although these are PRICEYYYYYYYY...Stock width performance stuff is great, but their +2 kits are tempting
it's just money
Old 05-07-2019, 12:17 PM #15
chrissurfr chrissurfr is offline
Real Name: Chris
chrissurfr is on a distinguished road
Real Name: Chris
well these need regreasing every 10-15k miles like the upper control arms?
2017 Cement Grey TRD Pro
C4 Fab sliders
Prinsu 7/8 roof rack
King Shocks with adjusters
SCS 17x9 f5 with 285 Nitto Ridge Grapplers
chrissurfr is offline   Reply With QuoteReply With Quote
arms , control , expedition , lower , series
TOTAL CHAOS Upper Control Arms TOTAL CHAOS 5th gen T4Rs 77 03-18-2024 10:44 AM
Will total chaos stock length race series control arms fit my truck with 17x9 SCS f5? chrissurfr 5th gen T4Rs 2 03-13-2019 01:34 AM
anyone running total chaos stock length lower control arms? chrissurfr 5th gen T4Rs 3 09-17-2018 01:06 PM
Total Chaos Lower Control Arms (stock Length) schwari1 4th Gen T4Rs 10 07-28-2014 07:10 PM
