Old 03-14-2024, 10:26 PM #1
philskeeter philskeeter is offline
philskeeter is on a distinguished road
Help with whining noise
The searches IÂ’ve come across seem to all be people talking about the humming noise where the vehicle is running a systems check after the vehicle has been off a few hours. IÂ’ve heard that noise and am familiar with it and this is not the same noise. IÂ’ve got a 2023 4Runner with 8,000 miles and IÂ’ve heard this whining noise probably 15 times start the past month. The first few times was while I was sitting at a stop light. I thought steering pump, but when I turned my steering wheel while hearing the noise, it never changed. Then I started to hear it within a few minutes of shutting the vehicle off so I ruled out power steering pump and bearing or tensioner pulley. My next best guess is a vacuum leak? ItÂ’s coming from underneath the vehicle and seems like it is near the fuel tank. Is it a fuel pump noise? I couldnÂ’t post the video, so here is a link to hear the noise
IMG 2920 - YouTube
I havenÂ’t taken it to the dealer yet because this noise doesnÂ’t happen every time I turn the vehicle off. From past experience, they use not being able to recreate the noise as a reason to not fool with it. Thanks in advance!
philskeeter is offline   Reply With QuoteReply With Quote
Old 05-30-2024, 05:16 AM #2
andreamoon andreamoon is offline
andreamoon is on a distinguished road
I am having the same issue now. Did you find any solution to solve this whining noise?
geometry dash scratch
andreamoon is offline   Reply With QuoteReply With Quote
Old 05-30-2024, 09:18 AM #3
Humble Leader's Avatar
Humble Leader Humble Leader is online now
Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold
I think it is definitely something to do with the fuel system. a smoke test would probably find the leak. if it's not a leak could be the charcoal canister. do you have a check engine light, poor performance and mileage?
Humble Leader is online now   Reply With QuoteReply With Quote
Old 05-30-2024, 02:04 PM #4
daronjh daronjh is offline
daronjh is on a distinguished road
I typically leave the wife & kids at home & magically the whining stops.
daronjh is offline   Reply With QuoteReply With Quote
Old 05-31-2024, 09:12 AM #5
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
Check if the noise changes with the fuel level. Does it get louder when the tank is full or low? Also, inspect the fuel lines for any kinks or damage.
A faulty fuel pump relay can cause whining noises. The EVAP system might also make strange noises if there's a small leak or the purge valve isn't working right. A smoke test can help find leaks in this system.
weberlukas74 is offline   Reply With QuoteReply With Quote
iâ’ve , noise , pump , steering , vehicle
HELP! AC Whining noise!!! _04runner_ 4th Gen T4Rs 0 07-22-2016 10:54 PM
Whining noise dozerfrelich 3rd gen T4Rs 8 08-03-2015 01:59 PM
Whining noise BROOKLYN Problems & Warranty Issues 3 04-22-2012 12:49 AM
Whining noise on my '03 03ToyotaFlo Problems & Warranty Issues 3 12-13-2009 12:47 AM
