Old 03-17-2024, 01:30 PM #1
Stimulant Stimulant is offline
Stimulant is on a distinguished road
Fixing timing cover reseal
Hi folks I have a 2014 Sr5 with 65,000 miles and I took it in to get the oil changed and they said that it is leaking oil around the seal, which they said was the Timing Cover Seal. They are going to try to get it fixed under warranty. He said the engine would need to be pulled for this to get fixed and 7500 which I will not pay for that. Anyway, has anyone ever experienced this type of a problem? If so, did it get covered under warranty? In not, what did you do?
I appreciate it.
Stimulant is offline   Reply With QuoteReply With Quote
Old 03-17-2024, 02:30 PM #2
Voltan73's Avatar
Voltan73 Voltan73 is offline
Real Name: Jason
Voltan73 has a spectacular aura about Voltan73 has a spectacular aura about
Voltan73's Avatar
Real Name: Jason
I'm a back counter partsman for a Toyota dealer, 23 years now. On the back counter, I work directly with the techs and service advisors. I see this on almost a daily basis, as many of these chain motors leak at the timing covers. The 3.5 in the Tacomas are the worst.
If the job is full customer pay, I believe the book labor time is close to 20 hours. There are a ton of little gaskets and o-rings, which add up quickly as well.
What you need to find out is the severity of the leak. If it's just a seep, then it does not need the re-seal yet, and should be monitored and checked at each service.
I really wish Toyota would've never switched from timing belts to chains; so many of these engines end up leaking. Don't get me started on the 5.7 cam towers!
Voltan73 is offline   Reply With QuoteReply With Quote
Old 03-17-2024, 07:49 PM #3
Thank you! I saw the pics from the tech and it is seeping so it is early on. Fingers are crossed it will be under warranty.
Old 03-18-2024, 08:45 AM #4
Ventil8 Ventil8 is offline
Real Name: Armando
Ventil8 will become famous soon enough Ventil8 will become famous soon enough
Real Name: Armando
$7500 for a timing cover seal leak??? I had this job done out of warranty for my 2005 4R and paid $1800 for the timing cover reseal, water pump, thermostat, serpentine belt, and full transmission flush. This was done at about 150,000…I think it was done in 2015 or 2016. currently have 198,400 miles on it. $7500 is highway robbery…even it the warranty is covering it.
Original Owner- 2005 Silver Metallic Sport Edition 4WD V6
Ventil8 is offline   Reply With QuoteReply With Quote
Old 03-18-2024, 08:59 AM #5
There is no way I would pay that.
Old 03-18-2024, 11:39 AM #6
CutthroatSlam CutthroatSlam is offline
CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of
Whether its belts or chains, they still have a timing cover. Have 350K miles on a 2014 and no leaks. So definitely prefer the timing chains.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 03-18-2024, 04:32 PM #7
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light
baldrik78's Avatar
I appreciate it.
That is outrageous. You do NOT have to pull the motor. You DO have to pull *everything* off the front of the motor (rad shroud, belt, clutch fan, water pump, pulleys, etc) and the valve covers to pull the timing cover.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
baldrik78 is offline   Reply With QuoteReply With Quote
fixed , oil , seal , timing , warranty
4.0 V6 How do you check the timing chain set up with the timing cover on? mopar346 4th Gen T4Rs 11 12-03-2021 11:36 PM
Rear main seal housing reseal Stiles97 3rd gen T4Rs 2 07-30-2017 12:38 PM
Rear diff armor (my way of fixing leaky rear cover) rm2fast 3rd gen T4Rs 5 02-21-2013 02:29 PM
Finished 3VZE injection reseal: comments 77'911 Classic T4Rs 5 04-28-2010 04:15 PM
In process: 3VZE fuel injection reseal..... 77'911 Classic T4Rs 4 04-25-2010 05:49 PM
