Old 03-27-2024, 02:48 PM #16
fkheath fkheath is online now
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Originally Posted by Apogeo View Post
You could also use this opportunity to swap for a better set of tweeters and better 6x9s in the door. If you search here a lot of people have great results from this swap. Go for a 6x9 component set and it is pretty close to plug and play.
Although a bit pricey, the OEM Audio+ speakers are 100% plug and play. No adapters needed, no wiring harnesses. They sound great.
fkheath is online now   Reply With QuoteReply With Quote
Old 03-28-2024, 09:31 AM #17
Grug556's Avatar
Grug556 Grug556 is offline
Grug556 is a jewel in the rough Grug556 is a jewel in the rough Grug556 is a jewel in the rough
Grug556's Avatar
If not JBL amplified system it is a 1" tweeter. I think this is the one you want, may be able to get it locally in Canada... fellow Canadian here, relocated to the States 5 years ago.
You will need a wiring harness like this, or Crutchfield will include the Metra ones with your purchase (or charge you $10 at most). You will need to install (solder) base blockers, or farm this out to someone. If you have a friend that can do this it takes 30 seconds.
You will also likely need speaker mounts. These are from Metra, I went a bit higher end since I opted for high end speakers and wanted to avoid flex etc. The Metra ones are likely close to stock quality.
The hardest part will be removing and reinstalling the door panel.
Stupid question here, but are all 1 inch tweeters same fitment? Could I say just get a basic tweeter 1 inch of crutchfield or whever and have it fit? I take I dont need wiring harness or solder for the tweeter or do I?
Thanks for the help on this. I am not very good at speakers and audio..but the ripping sound from the left front..has to go!!!
Grug556 is offline   Reply With QuoteReply With Quote
Old 03-28-2024, 09:40 AM #18
NorthPark NorthPark is offline
NorthPark will become famous soon enough NorthPark will become famous soon enough
You'll want to stick with the suggested tweeters that others have used, often even then they still require a modification to make them fit.
The kicker/subaru tweeter drop in makes an amazing difference in a stock setup. I blew mine though and I think installed Focals as a replacement.
I also ran mildly upgraded speakers (power bass from eBay) on the stock head unit which made a solid difference for around $250 (all speakers replaced). These speakers aren't at the level that require a dedicated amp and worked well.
NorthPark is offline   Reply With QuoteReply With Quote
Old 03-28-2024, 11:00 AM #19
Grug556's Avatar
Grug556's Avatar
On the OEM + site, not sure if I read it right but it makes you buy the whole set instead of just say a pair?
Ugh confused!
Old 03-28-2024, 11:15 AM #20
Ugh confused!
Yes. It is a complete set.
Old 03-28-2024, 02:31 PM #21
ShermanOlsen ShermanOlsen is offline
ShermanOlsen is on a distinguished road
I think go for one of the recommended drop-ins, as NorthPark suggests. Since you listened to the stock system for years the Kicker/Subaru will be everything you need and will take less than half-an-hour to swap.
ShermanOlsen is offline   Reply With QuoteReply With Quote
amp , car , option , stock , watts
Time for a brake upgrade - recommendations requested bowrappyo 3rd gen T4Rs 15 03-30-2021 10:59 PM
2007 Time for oil change, input requested. LinuxHack3r 4th Gen T4Rs 18 05-23-2019 02:18 PM
I think its time for a speaker upgrade... Bumbo 4th Gen T4Rs 19 04-25-2017 10:06 PM
Trailer Advice Requested... Rollinthundr 4th Gen T4Rs 5 06-21-2011 07:02 AM
Advice on affordable front speaker upgrade ksneubec Engines / Suspension / Wheels / Tires / Audio / Accessories 9 05-31-2006 01:03 PM
