Old 03-26-2024, 10:29 AM #1
Rick G. Rick G. is offline
Rick G. is on a distinguished road
Pics- Bilstein 5100 Front Lift
Hello all. Quite some time ago I inquired here about doing a minor front lift on my 2022 4RUNNER SR5 Premium 4WD, mainly for appearance purposes. Thanks again to all who replied at that time with your advice.
I elected to go the route of having my local off road shop install a pair of Bilstein 5100 Series adjustable front shocks. I asked them to raise the front enough to eliminate most of the front rake, but to leave a hint of front rake.
I am extremely happy with the results, both with the ride, and with the change in appearance. My shop took care of getting a front end alignment done after they installed the Bilsteins. Vehicle drives great.
I shot a few pics here to share, especially for anyone who is considering getting this same work done. I don't think you will be disappointed if you go through with this mod.
Here is my pride and joy, pics shot recently, with the vehicle odometer reading 34,107 miles.
Pics- Bilstein 5100 Front Lift-img_0210-jpg  Pics- Bilstein 5100 Front Lift-img_0211-jpg  Pics- Bilstein 5100 Front Lift-img_0219-jpg  Pics- Bilstein 5100 Front Lift-img_0215-jpg
Rick G. is offline   Reply With QuoteReply With Quote
Old 03-26-2024, 11:00 AM #2
///AIRDAM's Avatar
///AIRDAM ///AIRDAM is offline
Real Name: Adam
///AIRDAM will become famous soon enough
///AIRDAM's Avatar
Real Name: Adam
berry nice
Pics- Bilstein 5100 Front Lift-img_0533-jpg
current
2005 Tundra DC limited + 2008 4R Urban Runner + 2023 4R TRD Sport
past
2008 Tacoma TRD Sport DC TRD supercharged + 2012 4Runner Limited
///AIRDAM is offline   Reply With QuoteReply With Quote
Old 03-26-2024, 11:02 AM #3
fourrunnerbill fourrunnerbill is offline
fourrunnerbill is on a distinguished road
Just curious how did they raise the front with 5100's. My shop said they couldn't do that unless the springs were changed out.
fourrunnerbill is offline   Reply With QuoteReply With Quote
Old 03-26-2024, 11:18 AM #4
fourrunnerbill,
Hello. Maybe check with another off road shop for a second opinion. The Bilstein 5100s are designed to be used with your existing coil springs, when replacing your FRONT shocks.
Unless maybe your shop thought your mileage was too high on your current springs, or they were afraid of the age of your vehicle, and they wanted to go with fresh coil springs. Or, maybe they want you to spend additional money with them needlessly on more parts.
I am no suspension expert. Let's see if someone else here with experience on this matter can chime in. Thank you.
Old 03-26-2024, 11:35 AM #5
premise premise is offline
premise is on a distinguished road
Are these shocks pressurized enough to add significant "spring?" They are not "air shocks" per se, correct?
premise is offline   Reply With QuoteReply With Quote
Old 03-26-2024, 11:39 AM #6
El Dusty's Avatar
El Dusty El Dusty is offline
El Dusty has a spectacular aura about El Dusty has a spectacular aura about El Dusty has a spectacular aura about
El Dusty's Avatar
Bilstein 5100s are literally designed and marketed to be used with all vehicles stock springs. Your shop is lying or incompetent or both. Best to find a new one.
El Dusty is offline   Reply With QuoteReply With Quote
Old 03-26-2024, 11:46 AM #7
Here's a youtube video I found. The guy mentions near the beginning of the video that the existing coil springs are being re-used in the installation, for FRONT shocks.
The Bilstein 5100 shocks are nitrogen gas charged / pressurized, to work in concert with the oil also contained in the shocks.
They are NOT "air shocks" per se, where you can raise or lower the air pressure in them. You have to select your ride height on these before you install the shocks on the vehicle. After that, if you want to change your height, it looks to me like you would most likely have to remove the shocks from the vehicle, make your re-adjustment, and then re-install them on the vehicle.
Youtube video link:
https://www.youtube.com/watch?v=dEnMvblCHyo
Old 03-26-2024, 12:05 PM #8
I wasn't clear. They did install 5100's front and rear with no other mod and they are an improvement over stock shocks. But when I asked if they could give it a .5 - .8 " rise they said they could for the rear but not for the front unless springs were changed out. This was discussed prior to the work so the height was pretty much the same. Some future day I might consider a better solution. I seem to manage fine on easy trails and occasionally medium ones.
Old 03-26-2024, 12:39 PM #9
Youtube video link:
4Runner Bilstein 5100 Front Shock Install - YouTube
Ah, got it, the shock provides for ride height adjustment via preload via spring seat position selection. Thanks!
Old 03-26-2024, 09:04 PM #10
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
I will reiterate what El Dusty said. Your shop is either lying or incompetent.
It's the opposite of what they said. The front 5100's are lift height adjustable and meant to be able to work with stock springs. They have 4 snap ring grooves that allow lift heights of 0", .85", 1.25", 2.5". The rear 5100's are not height adjustable but are designed to be able to work with taller springs or spacers. If you want the rear lifted then you would need new springs or use spacers.
I have 5100's on all 4 corners using the OEM springs. The fronts are set to .85" and the with the rears I have 1/2" spacers.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 03-28-2024, 11:41 AM #11
OK, it appears he just mis spoke and got the rear and front mixed up. Thanks for the clarification and I will keep things as is (not wanting to use spacers) and consider a more aggressive solution in the future.
appearance , front , shop , shot , vehicle
FS: Bilstein 5100 Front Shocks 0-2.5" lift for 4th gen - $150 stell4r For Sale: Suspension/Wheels/Tires 6 12-15-2021 11:08 PM
One more Bilstein 5100 front lift, 0 rear lift question. Hugo Stiglitz 5th gen T4Rs 31 08-07-2020 10:29 PM
Question on Bilstein 5100 front lift for 05 SR5 Z man 4th Gen T4Rs 1 05-14-2013 06:50 PM
Bilstein 5100 lift (pics) Jared Pabis 3rd gen T4Rs 16 04-24-2011 08:12 AM
Front Bilstein 5100 shocks, FJ Springs, And Daystar 1.5" Rear Spacers Installed -Pics man03999 4th Gen T4Rs 39 06-12-2010 11:03 PM
