06-06-2022, 05:43 PM
$10K KDSS Repair!!
Hi all, Our local Toyota dealer quoted me $10,000 to fix the KDSS system on my 2010 4R Trail, with 220K miles. The KDSS light comes on now and then, and they said it was very rusty (salty upper Midwest roads) and leaking slightly from the unit. The $10K is to replace the unit and all four lines. Does this sound right to you? Many thanks for sharing your insights!!
06-06-2022, 05:49 PM
Real Name: Danny
Real Name: Danny
Is insurance claim an option?
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg BJ UCA's Fox 2.5 Resi rear W/ Icons. Method 701's, Cooper S/T Maxx 285/70/17. Shrockworks sliders. LLama Tales
Dual Battery Thread
06-06-2022, 06:02 PM
source your own used parts and replace whats failed. thats ridiculous.
06-06-2022, 06:11 PM
Good to know there’s a warning light for KdSS! Thx!
06-06-2022, 06:14 PM
For that age of vehicle and that quoted cost of repair, I'd just pull the connector and turn off KDSS. That said, it'd be worth getting a quote from a non-dealer repair shop.
06-06-2022, 06:15 PM
I've heard of expensive KDSS repairs, but that is ridiculous. My guess is that dealership doesn't have the equipment to perform the work. If it completely fails, it would be a great time to install an aftermarket setup.
06-06-2022, 06:20 PM
Real Name: Ron
Real Name: Ron
Yep, those high tech systems are great (I guess) when they work, but when they don't it's often way too expensive for most of us to have pay to get it working right again. Can it be removed/replaced with normal sway bar system like Xreas can with normal shocks?
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
06-06-2022, 07:15 PM
Real Name: Brandon
Real Name: Brandon
Reach out to Dr. KDSS and get his take on your situation.
Sent from my SM-F711U1 using Tapatalk
2016 Toyota 4Runner TEP + KDSS + RC
1971 Volvo 142e (Lovely brick with a tractor engine)
1977 International Scout II (Another brick tractor)
06-06-2022, 08:59 PM
I second dr.KDSS, Dom is super passionate about what he does and is a super cool dude
06-06-2022, 09:12 PM
are you running stock suspension?
another option is to take out the kdss system and upgrade your spring coils to a heavier weighted version to negate the loss of the sway bar.
this is my plan once my system fails.
or like others have stated, just replace the parts that need to be replaced.
i got the stuff
06-06-2022, 09:31 PM
Second this.
Also, take it to a Lexus dealer and see what they say. They see KDSS on every LC and GX, so they likely have more experience with the system.
06-06-2022, 11:17 PM
x4 reach out to dom aka DR.Kdss. this isnt voodoo, its just a hydraulic system, and he's repaired them.
you can unplug the white connector under the dash by the gas pedal area and the kdss light will always be on ;)
06-06-2022, 11:21 PM
yeah, with the stock suspension, kdss vs no kdss was night and day. After upgrading the suspension, the difference is lot less noticeable. If you're running a stock suspension, can just spend the money on a new suspension and just unplug the kdss wire by the module.
06-07-2022, 12:18 AM
KDSS is definitely off the list of options on the next 4Runner.
06-07-2022, 12:37 AM
We really like our Kdss. OP has 220k miles in the rust belt. Probably not many of the competition vehicles from 2010 still on the road in high salt use areas.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
