Old 04-03-2024, 07:39 PM #1
scfw0x0f scfw0x0f is offline
scfw0x0f is on a distinguished road
Electrical woes, voltage dropping
The voltage when idling starts at about 14V when just started, but after about 15 minutes of driving drops to about 13.45V, also at idle. We saw it drop to about 13.0V or 12.9V on Saturday while driving. No mods connected.
The battery was deeply discharged twice a few weeks ago, down to about 10V once and below 6V the second time. Now, when resting, it's dropped from 12.5V yesterday to 12.4V today, 24 hours between readings, truck parked the whole time. No weird temperatures, 40s overnight and 60s-70s daytime.
Is it likely one or more cells in the battery are bad, and that's dragging down the alternator? Shop did a load test, says the alternator was fine for 10s @ 130A. Battery was said to be okay if a bit low.
scfw0x0f is offline   Reply With QuoteReply With Quote
Old 04-03-2024, 09:12 PM #2
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
All your tests point to everything being OK. But you should get a battery load test, not the alternator.
fkheath is offline   Reply With QuoteReply With Quote
Old 04-04-2024, 10:45 AM #3
battery load test
That's likely what the shop did, but they also said they tested the alternator as well.
I would have sworn that the 5th Gen still had a fixed voltage alternator, not a Euro 5/6 "smart" alternator. Is that not correct? My recollection is that the alternator was steady at ~13.8V until recently.
Old 04-04-2024, 11:56 AM #4
The alternator output voltage can vary depending on temperature. All your voltage measurements are OK. (Keep in mind that the temperature in the engine compartment will be much higher than the outside air).
Yes, draining a battery down can damage it and shorten it's life. Your measurement of 10 volts indicates one bad cell (2 volts/cell), and 6 volts indicates three bad cells.
A battery load test (measures CCA -- cold cranking amps) will quickly show a bad battery. What is the measured CCA of your battery?
Since the alternator test shows it putting out 130 amps, that is not the problem/issue. When alternators go bad, it is usually the diodes and you will loose one or two phases of current (alternators are three phase). When you loose a phase due to bad diodes, you will get a sound on the AM radio that varies in frequency depending on engine RPM.
Two suggestions:
1. All batteries go bad eventually. You could be preemptive and get a new battery now.
2. Buy a quality jump box and keep it around so you don't get stranded when the battery does eventually go bad.
I did #2. My OEM battery is now six years old, and still going strong, but just to be ready when it does go bad, I got this: Amazon.com
Old 04-04-2024, 03:31 PM #5
Rocko9999 Rocko9999 is offline
Rocko9999 is on a distinguished road
How old is the battery?
Rocko9999 is offline   Reply With QuoteReply With Quote
Old 04-05-2024, 12:21 PM #6
AMLOR AMLOR is offline
Real Name: Kirk
AMLOR has a spectacular aura about AMLOR has a spectacular aura about
Real Name: Kirk
[QUOTE
I would have sworn that the 5th Gen still had a fixed voltage alternator, not a Euro 5/6 "smart" alternator. Is that not correct? My recollection is that the alternator was steady at ~13.8V until recently.[/QUOTE]
Depending on the year, some do...my 2019 is a perfect example.
The "Smart Alternator" can be made "Stupid" (a good thing) by using the "GM Diode Fix"
I dont have the thread handy, but do a search on the forum and you will run across the details. There are several different threads on this as I recall...
I did this on mine a couple of years ago and have never looked back. The alternator happily keeps both batteries fully charged with no residual issues.
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
AMLOR is offline   Reply With QuoteReply With Quote
Old 04-05-2024, 03:14 PM #7
Doodle210 Doodle210 is offline
Doodle210 is on a distinguished road
I had a similar issue a few months ago with a NEW battery. It got deeply discharged (I have an always on dashcam) while I spent two weeks in IL and came back to a dead battery. It was charging, but wouldn't hold a charge. My truck was dying about 10-15 mins into a drive if I came to a red light or stop sign.
Thankfully I bought it from Costco, I told them what was going on and they swapped it out.
2016 4Runner Trail Edition Magnetic Gray
Mods done -
Under-hood LED light strip
In-Grill Hidden LED Bar
S&B CAI
Doodle210 is offline   Reply With QuoteReply With Quote
alternator , battery , driving , time , voltage
Battery voltage dropping randomly after new alternator, battery and serpentine belt almostbasic 5th gen T4Rs 11 07-10-2023 11:00 PM
Running "warm", voltage output dropping. . .what gives Jetcycles 3rd gen T4Rs 17 01-12-2016 03:05 PM
Weekend mod electrical woes poncharello 4th Gen T4Rs 12 03-08-2014 02:45 AM
Dropping the oil pan in a 3.0 miner88 Classic T4Rs 4 03-25-2012 08:19 PM
Hella 500 Electrical Woes KellyJ 3rd gen T4Rs 8 01-23-2010 08:44 PM
