01-27-2023, 02:44 PM
Akebono ProACT Ceramic vs Factory OEM Break Pads
I’ve heard many good things about the Akebono break pads. Even the Car Care Nut guy gives them a thumbs up. Have any of you used these on your 4Runner? What are your thoughts?
For clarification I’m not looking for high performance brakes pads. I’m curious if the Akebono provides better breaking but still has a similar performance as the factory OEM brake pads.
One thing I can say about my current rear pads (the cheaper version Toyota sells) are down to about 15% and the rotors still feel smooth.
Thanks
01-27-2023, 03:28 PM
I have not done a back to back comparison but in my somewhat limited experience I have preferred the Wagner OEX ceramic brake pads over the Akebono ceramic pads.
OEX 976 front and OEX 606 rear.
Jeremy
01-27-2023, 03:34 PM
Jeremy
Can you provide more details as to why?
01-27-2023, 05:11 PM
The OEX has a good initial bit when cold, stopping power is great and consistent across all of the regular driving scenarios.
The Ackebono have poor initial bit, especially when cold.
Each have low dust as you would expect with a ceramic pad.
01-27-2023, 05:39 PM
Thanks for that info! Out of curiosity do your rotors wear down smoothly or do groves form.
01-27-2023, 05:59 PM
Real Name: Carlos V.
Very satisfied with my akebono ceramics after 20k kms. Better stoping power than OEM and no dust. Have not tried other ceramics pads
Gold 2003 4Runner SR5 V6 2WD A340E
Grabber A/T, Brembo rot, Akebono pads, Optima batt, HKB Volt. booster, Buffalo Bayou recovery
Sony XAV1000, LED interior and reverse, Weathertech, Flux-Turbocharged tire valve caps.
01-27-2023, 06:46 PM
i liked the akebono pads (also liked them on my f250). however i warped the rotors recently so just went with whatever autozone stuff they had in stock.
01-27-2023, 08:10 PM
I have ran OEM and Akebono pads. Comparing the two, Akebono pads have better pedal feel but I would agree initial cold bite is lacking. I mainly switched to something other than OEM because I was wanting better initial bite. I feel like there is a lot of pedal travel before OEM pads bite. I experienced low dust with both pads.
01-27-2023, 08:19 PM
As far as stopping power between the two do you feel Akebono is a little better or on par with OEM. Also how about wear on the rotors? Do they wear down smoothly or create grooves?
Thanks
01-27-2023, 09:19 PM
I have them on my hemi grand cherokee WK. They stop good and don't seem to wear as fast as regular semi-metallic pads. Low dust on the wheels too.
2022 4Runner TRD Off Road Premium, Front Bilstein 5100’s/Rear Rancho RS9000x, RCI Skid Plate, Goodyear Duratracs.
01-27-2023, 10:39 PM
I really like the Akebono ProACT pads and recommend them. Decent price and good performance. I like that they do not require a break in procedure.
In my experience they do not "warp" the rotors like OEM pads do. Which is the original reason I switched to them. No matter how easy I tried to be on OEM pads I would end up with "warped" rotors after 30k miles or so. I have not had any "warped" rotors with the Akebono ProACT pads.
2019 TRD ORP
01-28-2023, 09:41 AM
Thanks
Stopping power feels a little better and rotors are wearing smooth with no grooves.
01-28-2023, 10:13 AM
lol i warped mine with akebono pads. And put grooves in. more about how hard you are on them IMO.
01-28-2023, 01:25 PM
No doubt. I'm not hard on my brakes but I don't baby them either. In my case warping was inevitable with OEM pads but it hasn't happened with Akebono pads.
2019 TRD ORP
01-30-2023, 11:44 AM
The best combo I have found is Centric rotors with Akebono pads.
2011 SR5 4x4, Toytec Ultimate w/ SPC UCA's, Shrockworks Front Bumper, 285/70/17 BFG KO2, NFAB Steps
