Old 04-18-2024, 02:08 PM #1
TRDHULK's Avatar
TRDHULK TRDHULK is offline
TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold
TRDHULK's Avatar
Spare tire carrier options....
From what I can find, I don't care for any of the options out there.
I cant fit a 35" spare in the OEM location.
I'd prefer not to cut a hole in my rear bumper.
Most of the hitch mounted carriers I've seen don't sit very close to the body and look like an after thought.
I also don't see many options with a decent rear camera relocation kit.
What is everyone's spare tire carrier solution?
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit my LinkTree for discounts at Cali Raised LED, RRW, Rago, Canvasback,
Auxito, Diode Dynamics, Insta360, Ghost Mount, Giraffe Tools, and more
TRDHULK is offline   Reply With QuoteReply With Quote
Old 04-18-2024, 02:30 PM #2
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
Full replacement bumper with swing outs
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 04-18-2024, 02:43 PM #3
///AIRDAM's Avatar
///AIRDAM ///AIRDAM is offline
Real Name: Adam
///AIRDAM will become famous soon enough
///AIRDAM's Avatar
Real Name: Adam
You only have a few options:
1) cut to fit, you can "squeeze" a 33" in there but its touching the forward hangers and the trailer hitch, if you want to fit a 35 you are likely going to have to notch the trailer hitch and cut the little hangers off the front near the rear end as well or its just not gonna fit unless it hangs WAY down. I have our 305/50-20 spare under ours and it is SNUG and it hangs way down past the hitch. I have a 285/60-18 (31.6x11.2) on my 4th gen which seems like it fits much better, i bet you could swing a 34ish under a 4th gen, but the 5th gen is tight tight with that 305/50-20 (32.3x12.1)
2) put it on the roof and show it off and hope you dont ever have to pull it down.
3) go old'school early 90s suburban and put it in the back against the rear side glass, a 35x12.50 is going to take up a ton of room but it will fit, i just measured.
4) the tire swing outs will allow you to fit whatever you want, but it will impact the look of the vehicle tremendously. Do not recommend.
current
2005 Tundra DC limited + 2008 4R Urban Runner + 2023 4R TRD Sport
past
2008 Tacoma TRD Sport DC TRD supercharged + 2012 4Runner Limited
///AIRDAM is offline   Reply With QuoteReply With Quote
Old 04-18-2024, 02:51 PM #4
chrisridebike8 chrisridebike8 is offline
chrisridebike8 will become famous soon enough
I have the Rigd Ultraswing. It's well built but I smack it on the ground everywhere. It's annoying. If I could do it again, I would get the Dissent swingout. It can transfer to their high clearance bumper later on if you want to upgrade. I'd just get a Dissent rear bumper now. It's well built, high clearance, and the latch mechanism makes it the least painful in day to day use. And if you end up not liking having a swingout for a daily (understandable) you can remove it when you don't need it
2021 MGM 4Runner TRD Off Road, KDSS
Eibach | Falken | CaliRaised | Sherpa| Joe's | Rago | Odyssey | Redarc | Rigd | Waterport | Baja Designs | Diode Dynamics | MaxTrax | Level 8 | OVS | S-Tech | Midland | Dr. KDSS | ARB | JLT | Anzo
2022 MGM Corolla Hatchback 6-speed
2010 Black/Black C63 AMG, 460 whp (I miss this car every day)
chrisridebike8 is offline   Reply With QuoteReply With Quote
Old 04-18-2024, 02:55 PM #5
TRDHULK's Avatar
TRDHULK's Avatar
That is a solution, but that is not what I want to do. Not the look I'm going for with my 4Runner.
I do like the Nguyen Works high clearance rear bumper, but I use my hitch way too often to live without one. The OEM hitch crossmember shows way too much with the high clearance bumper and looks like booty. Plus this requires cutting up the rear bumper which I am trying to avoid for now.
Old 04-18-2024, 03:04 PM #6
TRDHULK's Avatar
TRDHULK's Avatar
Thanks for the reply!
1. I'm going to look into this, but ultimately even if I can find a way for it to fit in OEM location, it will hang way low and hurt departure angles a lot.
2. Wont be able to fit it my garage. I beat on it but at the end of the day its a garage queen lol.
3. This is a decent solution, but seems unsafe, unless there's a cool mounting solution I have not seen yet. The old Excursions were done this way. Not a bad idea, but would be unsafe unless properly mounted, which sounds like some screwing into the floor may be required.
4. I'm sure this is the route I will have to go, but just have not found a solution I like. I want it snug to the lift gate. I want a rear camera relocate that actually works well. I don't want it to look like an after thought. I might be SOL
Old 04-18-2024, 03:09 PM #7
TRDHULK's Avatar
TRDHULK's Avatar
Thanks for the feedback on the Rigd unit. That is one I considered, but I was worried about scraping it off road. It also sits farrr from the liftgate.
Are you saying Dissent offers a swing out without using the whole aftermarket rear bumper? I don't see it on their site.
Old 04-18-2024, 03:12 PM #8
MasterFoo MasterFoo is offline
MasterFoo will become famous soon enough
I use the southern style offroad. It is an authorized copy of the ctnewman. It sits closet to the hatch. I only use it when I take risky trips, otherwise I dont carry a spare.
MasterFoo is offline   Reply With QuoteReply With Quote
Old 04-18-2024, 03:27 PM #9
91foxbody 91foxbody is offline
91foxbody will become famous soon enough 91foxbody will become famous soon enough
Modular Hitch Mounted Tire/Accessory Carrier (Dual Swing)
– Dissent Off-road
Modular Hitch Mounted Tire Carrier (Single Swing)
– Dissent Off-road
91foxbody is offline   Reply With QuoteReply With Quote
Old 04-18-2024, 04:29 PM #10
TRDHULK's Avatar
TRDHULK's Avatar
Shows to be out of stock everywhere. So far this was my favorite swing out option but no one has it for sale.
Old 04-18-2024, 04:31 PM #11
TRDHULK's Avatar
TRDHULK's Avatar
Thank you. I don't hate it, but man is it chunky lol
Old 04-18-2024, 04:34 PM #12
comtn4x4's Avatar
comtn4x4's Avatar
I feel your pain. I didn't think I was going to do a rear bumper either till I moved to tires that wouldn't fit underneath anymore. And I was dragging my spare and the rear bumper cover. (I ran an undersized spare for awhile, if you don't flat much you could consider stuffing a skinny 34" tire underneath.)
Now that I've had it 5 years I love it and couldn't imagine not having it. Much better storage for propane, fuel, water, hi-lift, traction boards, trash etc. And honestly dragging a 90# spare from underneath and shoving the flat one back under in off road conditions sucks.
I can't even imagine the nightmare of having my spare on my roof.
Old 04-18-2024, 04:44 PM #13
TRDHULK's Avatar
TRDHULK's Avatar
Here is my personal favorite so far, but NO ONE SELLS IT!!??
It says its from Detours Knucklebone, but I don't see where to buy it from, if anyone knows please lmk
This is my 2nd favorite, from Eighty Percent Off Road, but it requires cutting the bumper, which I prefer not to do. This one sits the cleanest on the 4Runner IMO
I also like this one from Restless Off Road Fabrication, but also requires cutting the bumper.
I don't mind this one; Southern Style Off Road, but EVERYONE is out of stock!
Now you can see my frustration lol. Either no longer sold, out of stock, or requires cutting
Old 04-18-2024, 04:45 PM #14
I could be wrong, but I believe they are made to order. iirc, when I ordered mine, it was also out of stock. It took about 8 weeks and was delivered by UPS.
I would contact them if you're going that route.
Old 04-18-2024, 04:49 PM #15
TRDHULK's Avatar
TRDHULK's Avatar
I'm sure this will be the boat I am in soon. I just don't want a big heavy bumper yet. I like my OEM+ look
carrier , options , rear , spare , tire
Spare tire carrier security / Dmos tire mount mrblah 5th gen T4Rs 0 11-11-2023 09:18 PM
WTB: Spare tire carrier for 03-09 pearlj10 Want to Buy/Trade 0 12-11-2016 12:50 PM
WTB: 4th Gen Spare Tire Carrier and Carrier Guide jkemp Want to Buy/Trade 0 10-09-2015 02:17 PM
Spare tire carrier? 2nd gen. mack1 Classic T4Rs 7 09-24-2014 04:26 PM
Spare Tire carrier options? Gen2 chenson Classic T4Rs 5 04-08-2011 04:05 AM
