Old 04-21-2024, 07:44 PM #1
Soulprogression108's Avatar
Soulprogression108 Soulprogression108 is offline
Soulprogression108 is on a distinguished road
SPC Upper Control Arms grease type?
Anyone running the SPC upper control arm for 5th gen that has the grease zirk? can you confirm what type of grease? is it 3% Moly? having trouble finding the specs. The one's on my truck appear to be possibly leaking at the boot. Maybe it's not a big deal or maybe a common thing? Either way I'd like to grease them and try to fix the seal.
Thanks!
Current: 2011 Trail Edition T4R
Bilstein Leveling Kit: 6112's and 5160's
TRD 17" Gold Wheels 31" TA's
Sold:1994 T4R 22re 4x4 MT
Aluminum Weld 15's and 31x10.5 BFG ATs
Soulprogression108 is offline   Reply With QuoteReply With Quote
Old 04-22-2024, 08:52 PM #2
AMLOR AMLOR is offline
Real Name: Kirk
AMLOR has a spectacular aura about AMLOR has a spectacular aura about
Real Name: Kirk
Thanks!
I use the molly stuff, but any good quality heavy grease will work. But DO GREASE THEM, regularly and often!
I just put my 3rd set of the upper ball joints on about a month ago.
I have been getting about 33K ish miles on those, but i have a heavy front end on the truck.
The ones I used to do the replacement is a new, "sealed" and pre greased set. Time will tell if these last any longer than the greasable ones...
AMLOR
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
AMLOR is offline   Reply With QuoteReply With Quote
Old 04-22-2024, 10:30 PM #3
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Thanks!
Anything with a zerk is meant to expel grease; that's the way you tell you have them filled. Sometimes there is a "port" where you can see a bead of grease coming out, but sometimes the excess grease just comes out the edge of the boot. When you fill them with grease, you may be able to see where the excess grease is coming from and determine if there is a tear in the boot.
fkheath is offline   Reply With QuoteReply With Quote
Old 04-23-2024, 09:26 AM #4
Offroad Alliance Offroad Alliance is offline
official vendor
Offroad Alliance is on a distinguished road
official vendor
Thanks!
from SPC On their approved greases:
Chevron® Delo ESI HD 3% Moly, 259122652 tube
Chevron® Delo ESI HD 5% Moly, 259120652 tube
Citgo® Lithoplex CM2, 665357001080 tube
Citgo® Lithoplex HM2, 655357001080 tube
Lubriguard® Hi Temp Moly, 701654 tube
Lubriplate® No. 3000 Moly-Lithium, L0108-098 tube
Lubriplate® No. 3002 Synthetic Moly fortified HD grease, L0316-098 tube
Mystik® JT-6 w/Moly EP #2, 665056002 tube
Valvoline® Palladium 3% Moly, VV70112 tube
Valvoline® Palladium 5% Moly, 876339 tube
*Mobil 1® synthetic grease has acceptable test values but no Moly content, so it is NOT approved.
Offroad Alliance is offline   Reply With QuoteReply With Quote
Old 04-23-2024, 01:13 PM #5
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
AMLOR
help me understand...how does front end weight affect the life of UCA ball joint? the joint moves up and down but i dont think increased weight is applied to the joint if you add vehicle weight. Or am i wrong??
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 04-23-2024, 05:41 PM #6
Thanks everyone! I got an email from SPC attached it below. They just sent this but didn't respond to the part about the boot leaking, but it sounds like that's pretty normal. I picked up some 3% Moly Lithium NLGI-2 and a second grease gun since I can use it for the slip yokes on the truck as well. I just greased the drive train and slip yokes with the non Moly stuff since the Manual said can do that too, but next time I'll pump in the Moly.
Old 04-23-2024, 05:43 PM #7
thanks I'll wipe them and look more closely. the guy I bought truck from had them installed pretty recently so I'm guessing they were just juiced up and after driving some miles it pressed out the excess.
Old 04-24-2024, 08:30 AM #8
jdm-v35 jdm-v35 is online now
jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough
The movement is up and down, but the ball joint also holds the spindle in place from cambering in/out so increased weight, side load force, and abuse would technically affect the life of it.
2018 TRD ORP w/ Magnuson
jdm-v35 is online now   Reply With QuoteReply With Quote
Old 04-24-2024, 11:58 AM #9
lewdog998's Avatar
lewdog998's Avatar
ok, makes sense...did not think about that side loading.
Old 04-24-2024, 06:17 PM #10
Eons ago, I had a high school job as a grease monkey at a gas station. In those days, everything had Zerk fittings -- ball joints, tie rod ends, A arm pivots, drive axles, etc. The rule was to pump in grease until some grease got expelled, signaling the joint was full. A good grease monkey would wipe off the extra grease with a rag, but the lazy ones would just leave it to drip on anything below. Some cars became really messy that way; grease all over the place.
control , grease , spc , type , upper
FREEDOM Offroad Control Arms - Under $350 Tubular Upper Arms from Battle Born! Battle Born Offroad Suspension 26 06-14-2021 08:29 PM
WTB: 3rd gen upper/lower control arms/rear trailing arms BADCLOWN Want to Buy/Trade 2 05-24-2017 03:11 PM
what brand/type Control Arms to get? beliy25 4th Gen T4Rs 18 05-12-2016 10:08 PM
Which Upper Control Arms ? xcmountain80 3rd gen T4Rs 73 06-08-2015 08:12 PM
Upper Control Arms Mick1 For Sale: T4R Items 0 06-01-2012 05:50 PM
