Old 04-27-2024, 08:49 AM #1
BettysNephew BettysNephew is online now
Real Name: Dave
BettysNephew is on a distinguished road
Real Name: Dave
Replacement for high beam
One of my high beam bulbs burned out on my 2017 4R Limited so it is time for repair. My preference would be to go to LED for the high beam. I recall that the DDM Saber LED seemed to be the replacement of choice if one was going that route. Is this still the best choice in LEDs? I see there are now several wattage levels available. Is one superior to others? Does the high wattage one cause any issues electrically? Has any company actually solved the DRL flicker issue?
Thanks for putting up with all my questions.
2017 Blizzard Pearl Limited
Redwood guts
Gone but not forgotten:
2015 Attitude Black 4Runner Trail
BettysNephew is online now   Reply With QuoteReply With Quote
Old 04-27-2024, 12:16 PM #2
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Since the high beam bulb also doubles as the DRL, most LED suppliers say that LEDs will not work there. There are a few LED suppliers will say theirs will work, but I don't believe them.
Thus, you have three choices:
1. Conventional halogen available anywhere (auto parts stores, Walmart, etc)
2. A brighter/whiter light such as the Sylvania Silverstar and others. Those burn out sooner because the filament runs at a much higher temperature.
3. A 100 watt halogen bulb. I got the Phillips Rally Vision, but Hella also makes a good 100 watt bulb. Philips Rally Vision 9005 HB3 100W Two Bulbs Headlight High Beam High Watt Lamp | eBay
Just be aware, that anything over 55 watts is illegal for on road use, but in over 50 years of driving my Porsche with 100 watt H4 bulbs, I have never been stopped.
Suggestion: get the LasFit 4Runner Pro-DC kit for the low beams: Toyota 4Runner 2014-2020 Custom H11 LED Bulbs with Dust Cover | Pro-DC They are much, much brighter than the oem bulbs, very white, and if adjusted properly, have a perfect flat top pattern. They are so much better than the OEM, you may just decide to use them all the time and not even use your high beams.
Two downsides to the Pro-DC: they are a bit pricey, and they can be difficult to adjust properly for the best light pattern.
fkheath is offline   Reply With QuoteReply With Quote
Old 04-28-2024, 09:30 AM #3
Real Name: Dave
Real Name: Dave
Okay, here goes again, I guess I should have supplied more information...
I have HID in my low beams which work well and tried LED's first in the projectors and was not pleased with the results so do not intend to try them again. If needed I will disable the DRL by bending the pin on the HL relay if there are still no solutions to the flickering.
So I guess it boils down to knowing from which high beam LED you folks have had the best performance. Any suggestions about this?
Redwood guts
Old 04-29-2024, 01:19 PM #4
TRDHULK's Avatar
TRDHULK TRDHULK is offline
TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold
TRDHULK's Avatar
I have yet to find LEDs that work for the high beams without causing high speed flickering.
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit my LinkTree for discounts at Cali Raised LED, RRW, Rago, Canvasback,
Auxito, Diode Dynamics, Insta360, Ghost Mount, Giraffe Tools, and more
TRDHULK is offline   Reply With QuoteReply With Quote
Old 04-29-2024, 01:32 PM #5
hoppyjr hoppyjr is offline
hoppyjr has a spectacular aura about hoppyjr has a spectacular aura about hoppyjr has a spectacular aura about
This is what you want. Quality product, no flicker.
14-21 TOYOTA 4RUNNER V50 DRL/HIGH BEAM KIT
hoppyjr is offline   Reply With QuoteReply With Quote
Old 04-29-2024, 05:19 PM #6
TRDHULK's Avatar
TRDHULK's Avatar
Wow, that aint cheap!
Thanks!
Old 04-29-2024, 05:52 PM #7
Thanks!
Not cheap, but I’ve been using their products for many years and they just keep getting better and better. All my vehicles are using VLED products and I’ve never been disappointed.
beam , high , led , replacement , wattage
2021 TRDOR high beam replacement to LED? ltsatch 5th gen T4Rs 11 11-09-2021 03:08 AM
2005: Current HIR options for low beam (9006) & high beam (9005)? Iron Chef 4th Gen T4Rs 6 03-15-2021 09:07 AM
Headlight high beam position now low beam, low beam position no lights. dogtail 3rd gen T4Rs 5 03-28-2020 07:35 AM
HID (Low-Beam Xenon/ High-Beam Halogen) -H4 5000k 55w on Projectors Cuco 3rd gen T4Rs 7 08-07-2016 11:17 PM
question regarding my high beam/low beam pokits 5th gen T4Rs 2 05-21-2015 02:14 AM
