Old 04-28-2024, 01:45 PM #1
Ruby Khan Ruby Khan is offline
Ruby Khan is on a distinguished road
Electric Brake Controller? Best on for 2023 T4R?
Hi,
We want to try towing a small camp trailer. Despite it weighing less than 2000lbs, it has electric brakes, and I would like to make use of them.
I don't know anything about this stuff. After a few searches, I saw that several products are on the market.
I would like to install one that works very well and doesn't look like it's just been zip-tied to the steering column.
Any suggestions?
Thank you!
Ruby Khan is offline   Reply With QuoteReply With Quote
Old 04-28-2024, 02:01 PM #2
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
Did you get the towing package, or is it standard on your model?
I ask because gen 4 models have a connector in the left kick panel for a brake controller. It's just plug 'n play. I had to attach the holder under the dashboard, not another place to put it and it was recommended by the controller.
I use a well known and recommended Tekonsha Prodigy P2 Controller.
TEKONSHA (They have fit guides and video support)
The operation is pretty simple.
When the controller is set up, when you start the car the display will show "nc" if there is no trailer connection or "c" if there is. When you step on the brake, with trailer connected, the display will show you a number that corresponds to the amount of pressure being applied.
You get everything hooked up and then set the controller (scroll wheel) to a midpoint number. Drive with the trailer, preferably on a gravel road but any low traffic road will do. Apply the brakes and see how the trailer responds. If it's squealing tires / spitting gravel you want to go to a lower number. If it doesn't seem to be working go to a higher number.
The Tekonsha has a lever on the bottom for a temporary increase. You can move the lever with your thumb to apply more braking pressure without changing your default setting.
When I'm not using my P2 I just disconnect the plug and remove it from its holder. I keep it in the center console.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 04-28-2024, 03:01 PM #3
Hi,
Thanks for sharing info.
I should have stipulated that the 4 Runner is a 2023 TRD Off Road Premium. My impression is that there was no specific tow package, but It has a wired 7 pin connector and a 2" receiver that were included in that particular model trim.
I'll go read about your suggestion.
Thank you.
Old 04-28-2024, 08:49 PM #4
ArthurKotb's Avatar
Real Name: Rich
ArthurKotb's Avatar
Real Name: Rich
Check in the driver-side kick plate for that connector. The towing package is probably standard by now. It should have always been standard.
I believe it's a flat 4 pin connector, tucked just below the top of the kick plate. You shouldn't have to remove anything.
Rich
Kentucky
Old 04-28-2024, 09:44 PM #5
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Originally Posted by Ruby Khan View Post
Hi,
Thank you.
All 4Runners, all trim levels, come for the last few years with:
1. 2" tow hitch receiver.
2. Both a 4 flat and 7 pin trailer wire connector
3. AND "Trailer Brake Jumper Harness Wire Connections" adapter for a brake controller, part number 82132-600110. You should find this brake controller wire harness in the glove box.
My '18 4Runner SR5 came with all that, standard, not an "option".
All you need do is buy a brake controller of your liking, wire it to the supplied wire harness, and plug it in.
fkheath is offline   Reply With QuoteReply With Quote
Old 04-29-2024, 09:27 AM #6
Humble Leader's Avatar
redarc tow pro or tow pro elite. plug and play and has the cutout for OEM dash blank. very discreet and looks factory
Old 04-29-2024, 10:45 AM #7
hoppyjr hoppyjr is offline
hoppyjr has a spectacular aura about hoppyjr has a spectacular aura about hoppyjr has a spectacular aura about
Originally Posted by Humble Leader View Post
redarc tow pro or two pro elite. plug and play and has the cutout for OEM dash blank. very discreet and looks factory
^ This.
The Redarc is all you need. The Toyota specific switch blank is extra, but the switch is included. No cutting or splicing required and there are easy how-to videos on YouTube.
I started with my switch on the left side switch blank, but needed to use that space for other switches, so I moved the brake controller switch to under the stop/start button.
Redarc Tow-Pro Elite Electric Brake Controller - EBRH-ACCV3-NA
Switch Insert Panel for Toyota... Amazon.com
hoppyjr is offline   Reply With QuoteReply With Quote
Old 04-29-2024, 10:46 AM #8
Edit: double post
Old 04-29-2024, 10:47 AM #9
^ This.
Old 04-29-2024, 10:54 AM #10
ArthurKotb's Avatar
Real Name: Rich
ArthurKotb's Avatar
Real Name: Rich
My 2004 came with all that except the 4 flat connector, but the towing package was an option. I see now, as I suspected, that the tow package is standard.
The brake jumper harness is to use in case the connector in the driver's kick panel doesn't fit the brake controller you purchase. You can modify the connector with the jumper harness. The Prodigy P2 I bought worked with the connector so all I had to do was put 2 screws under the dash for the P2 holder. The P2 and P3 are excellent controllers. I pull a 6,500 lb. Airstream with my T4R and the controller is easy to use. I just take it out of the console, plug it in to the connector and head down the road.
Electric Brake Controller? Best on for 2023 T4R?-dscn1652-jpg
Rich
Kentucky
Old 04-29-2024, 10:54 AM #11
Hi Thank you.
I found the wiring harness right where you said it should be. :-)
Old 04-29-2024, 11:03 AM #12
ArthurKotb's Avatar
Real Name: Rich
ArthurKotb's Avatar
Real Name: Rich
That Redarc controller looks really nice. If it's performance matches it looks then that would be the way to go. I got my Prodigy back in 2014, based on reviews on the Airstream forum. I'm towing pretty close to the maximum and I didn't want that to come into me for an emergency stop.
Rich
Kentucky
Old 04-29-2024, 11:13 AM #13
Thank you.
Old 04-29-2024, 11:17 AM #14
Thanks, everyone.
I am going to try the Redarc Elite. It seems like they have it all figured out.
Thank you!
Old 04-29-2024, 11:31 AM #15
Posting these tutorial videos so I can find them later:
https://www.youtube.com/watch?si=32SYgiFShnaDIlR8&v=vKiCqg07AGs&feature=youtu.be
https://www.youtube.com/watch?si=GbccYmKhf3krFm6n&v=TnmbyLFmLgs&feature=youtu.be
electric , install , market , products , searches
FS: Tekonsha Prodigy P3 brake controller (Boston, MA) - electric & hydraulic xxaarraa For Sale: T4R Items 3 05-10-2017 08:44 PM
Electric trailer brake controller help Islands 3rd gen T4Rs 14 12-01-2016 03:02 PM
Brake controller gmillerok1 5th gen T4Rs 30 06-09-2016 11:00 PM
what electric fan controller are you guys using? jmt2404 3rd gen T4Rs 4 08-05-2011 10:21 PM
Which brake controller does everyone use? gkatmar General Discussions 5 09-08-2008 04:04 PM
