Originally Posted by Furagwa
Thanks for the clarification. Sounds like the front one ended up being an inch longer than the rear one. You mentioned having to grind the side down to fit into the bracket. Was that still true on when you used the RR on the LF?
That is correct. had to trim off roughly 1/4" on each side. I used a hand grinder with a zipcut wheel.
