Old 05-07-2024, 12:44 PM #1
shock003 shock003 is offline
shock003 is on a distinguished road
Issue retrofit 2021 Head unit
I have a 2016 with navigation and awful Entune 2.0.
Found a non-JBL/Navigation Entune 3.0 from a 2021.
It included the special coaxial cables to connect the navigation. I also bought the special harness from autoharness. However, when testing I get a message stating navigation App not installed! Yes, I know it is useless, but I want this to work properly and I use the built-in map as I drive on curving roads as a predictive measure.
Is this unit defective? Any ideas what to do? Anyone experience this? Urgh. Never an easy job.
Issue retrofit 2021 Head unit-screen-shot-2024-05-07-9-37-44-am-jpg  Issue retrofit 2021 Head unit-screen-shot-2024-05-07-9-37-26-am-jpg
shock003 is offline   Reply With QuoteReply With Quote
Old 05-07-2024, 02:04 PM #2
osugsxr osugsxr is offline
tad surprised that this would happen, I would try the following. I had no issues hooking the head unit i purchased
1. hard reset of head unit , reset back to factory settings
2. check for latest operating software and upload via usb. Even if you have it installed already may want to give it a try.
3. double check correct wiring (not sure if the gps wires were able to be plugged in different connectors) . GPS antenna plugged in?
Old 05-07-2024, 05:16 PM #3
Ok, I hooked it all back up. It went through a power cycle on its own and now seems to actually work. Whew.
And for Carplay I needed to select some unsuspecting feature (i forget what it was named) and that then let me activate Carplay and changed
the name of the feature to Carplay and that does indeed work now as well.
The App: Remote Connect was asking for a 6 digit PIN...but I probably can't use that feature anyway.
Old 05-08-2024, 05:21 AM #4
nice! its a good upgrade and adds a new feeling /look to the interior plus the car play feature. I use car play about 95% of time with pandora or spotify and waze/ google for maps.
Old 05-08-2024, 03:21 PM #5
schwein schwein is offline
schwein is on a distinguished road
I must be out of the loop, but are you guys using the 2021 screens in the older 4Runners, is it plug and play? I may need to look for one for my 2014!
2003 - 4Runner Limited V8 (Sold)
2014 - 4Runner Limited V6
2019 - GX460 Premium V8
schwein is offline   Reply With QuoteReply With Quote
Old 05-08-2024, 04:14 PM #6
emmantik emmantik is offline
emmantik is just really nice emmantik is just really nice emmantik is just really nice emmantik is just really nice
Yes it is. See link;
OEM 2020+ headunit with Apple Carplay/Android Auto into 2014-2019
2015 Magnetic Gray SR5P
emmantik is offline   Reply With QuoteReply With Quote
Old 05-08-2024, 08:32 PM #7
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Originally Posted by emmantik View Post
You have to buy an adapter harness. I don't call that plug and play. Plug and play to me means you can install it without making any modifications, including adapters of any kind.
fkheath is offline   Reply With QuoteReply With Quote
Old 05-09-2024, 07:24 AM #8
quick facts:
non jbl head units
auto harness adapter ( makes it plug n play)
hazard switch modification , simple to do but take your time!!!
source head unit
Car-Part.com--Used Auto Parts Market. (various pricing some as low as $200-900 range
Ebay will vary
local market place is helpful too
Old 05-09-2024, 10:03 AM #9
Calimander Calimander is offline
Calimander is on a distinguished road
One thing that I would add was the bezel on my sourced head unit had a few holes drilled in it that needed repair —so I bought a cover from Amazon for $40 or so and it looks OEM again.
Calimander is offline   Reply With QuoteReply With Quote
Old 05-09-2024, 10:04 AM #10
Actually after I saw how good it looked in matte black, I bought the rest of the trim covers and did the whole interior
Old 05-09-2024, 10:44 AM #11
Thanks for the info,
are there options for the Limited JBL head units, or will this only work with the N on-JBL stereo systems?
Old 05-10-2024, 06:18 AM #12
think there are options , reach out to autoharness house for more info.
entune , navigation , properly , special , unit
Retrofit GPS nav head unit in older 5th gen shock003 5th gen T4Rs 9 04-21-2024 02:59 PM
Need some help! - Head Unit issue r3apingcha0s 5th gen T4Rs 1 01-14-2022 04:38 PM
Head unit retrofit 2012 to 2016 Eddierluna 5th gen T4Rs 1 11-26-2021 12:21 PM
2021 Head Unit Replacement edizzle 5th gen T4Rs 9 04-18-2021 07:31 PM
Head unit issue bmodo16 3rd gen T4Rs 3 03-07-2016 10:47 AM
