Old 05-15-2024, 05:42 PM #1
FourT6and2 FourT6and2 is online now
FourT6and2 is on a distinguished road
OEM TRD Pro Fox Shocks Part Number?
I've called a few dealers and they haven't been helpful. One even went as far as to tell me 4Runners have never come with Fox suspension lol. I'm looking for the OEM part number for 2021 TRD Pro Fox shocks. I know they went through a few changes over the years but is this the correct number?
PTR61-89210
I also found this photo so I'm looking to confirm which spring/perch design the above number has if it is indeed for a 2021.
OEM TRD Pro Fox Shocks Part Number?-img_4395-jpg
FourT6and2 is online now   Reply With QuoteReply With Quote
Old 05-15-2024, 09:49 PM #2
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
2021-2022 Toyota 4Runner TRD Suspension Kit PTR61-89210 | Toyota Parts Center
2021-2022 Toyota 4Runner Genuine Toyota 4Runner TRD PRO Fox Suspension Kit PTR61-89210 | Elmhurst Toyota Parts
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 05-16-2024, 07:47 AM #3
SlvrRnnR's Avatar
SlvrRnnR SlvrRnnR is offline
SlvrRnnR will become famous soon enough
SlvrRnnR's Avatar
Interesting I had this on my list to upgrade my stock suspension 18' TRD ORP
with this kit and now says its discontinued? Was available a couple weeks ago??
Maybe a sign to go with Dobinsons, just wanted better upgrade and slight lift 1" or so.
PTR61-89210
SlvrRnnR is offline   Reply With QuoteReply With Quote
Old 05-16-2024, 11:40 AM #4
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
PTR61-89210
Any part with a "PT" part number is not factory installed, rather it is an accessory to be installed later.
fkheath is offline   Reply With QuoteReply With Quote
Old 05-16-2024, 12:22 PM #5
Correct. As far as I know, TRD Pro parts are installed at port of entry. That still doesn't answer my question though lol. Just trying to figure out the actual part number for the shocks on my car. They came on every 2021-2022 TRD Pro. 2023 and 2024 are different.
Old 05-16-2024, 12:30 PM #6
PTR61-89210
Weird. Shouldn't be discontinued. Probably just out of stock.
Old 05-16-2024, 11:44 PM #7
Hbc234 Hbc234 is offline
Hbc234 is on a distinguished road
What is different in the 2023/2024?
Hbc234 is offline   Reply With QuoteReply With Quote
Old 05-17-2024, 12:16 AM #8
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
@SlvrRnnR
The adjustable Dobinsons should do the same job with lots of adjustability for less.
I don't know if the springs they put on those settle; the regular Dobinsons springs I had did settle a lot. The various types of Bilstein and Eibach springs I have had, 5 total sets between front and rear, never really had excessive height.
I like Fox but I am not seeing the value unless your car came with them and you really liked them.
They are not racing shocks and the 4R cannot really race anyway. That said, it can smoke the Jeeps with simpler front shocks though the rear takes a beating which is why my setup is what it is.
Old 05-17-2024, 06:23 AM #9
SlvrRnnR's Avatar
SlvrRnnR's Avatar
Originally Posted by MAST4R View Post
@SlvrRnnR
Thanks @MAST4R good to know re Dobinson springs. I looked at Eibach also. I'll admit I like the stance of the Pro's and thought the TRD Fox kit would already have the any adjustments for left/right and I was able to download the install instructions that come with it. Was definitely waiting to find the right discount and use up some Toyota rewards points to make it more budget friendly. Don't do any major off roading here, mainly fire roads and some dirt/rock roads to camp sites on the New England coast for now. Oh and miles and miles of bunker sized pot holes.
Old 05-17-2024, 06:46 AM #10
SlvrRnnR's Avatar
SlvrRnnR's Avatar
I'm going to check w a local parts dept I've had good luck with and been using for years.
Toyota seems to replace or supersede part numbers now and then (and mis label things) and it takes awhile to correct. Or like you said maybe just out of stock and put into main database as discontinued. I wonder though also if the are now working with OME on the 2025's if there will be a new kit down the road.
OEM TRD Pro Fox Shocks Part Number?-screenshot-2024-05-17-6-29-21-am-jpg  OEM TRD Pro Fox Shocks Part Number?-trd-suspension-kit-toyota-ptr61-89210-jpg
Old 05-17-2024, 10:59 AM #11
MAST4R's Avatar
MAST4R's Avatar
If you want minute adjustability the Dobinsons should offer it.
For the rest, I am not sure what people find in the Eibach kit, is it threaded? if so, it could be what you need. But for offroading, those are small shocks and in the rear they are also short. Even 1" lift is noticeable in rock crawling--in a bad way. I have a pair of rear Eibachs for when I need to rebuild the 8100s.
If you don't need minute adjustments, what I have but on the regular springs will give you plush ride quality. You cannot push 6112 on standard springs hard offroad w/o making the bump stops work too hard, but for fire roads at normal speeds and for choppy pavement, they are perfect on the regular springs.
The only 1 thing to pay attention to if getting 6112s is that they changed the location of the notches on the shock so that one shock can accomodate multiple vehicles. What this means is that you may get a lot more lift than expected if the installer/you do not pay attention. It happened to me a month ago when I replaced the previous 6112 preventively. The new ones came on the same settings but gave me like 1.5" extra lift. That was not fun to deal with.
But assuming they are assembled at the correct height, 6112 on standard springs seem the ticket for you. I use them with stiffer springs which make them more capable offroad and less plush on road.
Good luck!
Old 05-17-2024, 08:13 PM #12
I mean... they HAVE to keep offering these shocks since every TRD Pro made since 2021 uses them. If I have a shock crap out and they need to replace it under warrantee, what are they gonna do if it's discontinued. 2021, 2022 aren't exactly "old" models yet.
Old 05-19-2024, 10:54 AM #13
jrm's Avatar
jrm jrm is offline
jrm will become famous soon enough
jrm jrm is offline
jrm's Avatar
Did just that with 6112s
jrm is offline   Reply With QuoteReply With Quote
number , oem , part , shocks , trd
Part number and source for fender flare part Kyngfish 3rd gen T4Rs 12 12-29-2023 05:25 PM
How can i find the part name/ catalog number for a specific part 9405t4r 5th gen T4Rs 2 07-13-2019 08:53 AM
Does anyone know the name and part number of this part of a 2015 Grill? brian0128 5th gen T4Rs 4 05-15-2017 09:55 AM
Can't find a part number on a bolt, dealer part guy was an idiot yota-runner 3rd gen T4Rs 8 02-02-2016 08:00 AM
OEM Shocks -whic part number is correct Ghostrider 3rd gen T4Rs 0 12-16-2007 07:03 PM
