use shorter bolts in the front rivnuts you installed and rtv them. Or just goober the hole with rtv. Amazon sells a roof rack delete kit to seal up the OEM mounting points for the other 4 spots. I remove mine every summer. i also no longer use the front spots where prinsu had you drill. i just bolted some rubber legs/bumpers to the front of the rack. it is bulky to do alone. i use some straps and hang it from the carport.
cut weatherstrip is still there. it's meh.
i'm midway through removing mine today. the more accessories/lights/radio antennae you have on it, the more of a hassle it is lol
