Old 05-18-2024, 08:02 PM #1
Chilow Chilow is offline
Chilow will become famous soon enough
Remove Prinsu Rack
Has anyone removed their Prinsu rack before? It’s the drill version before they released their non drill version. It’s been on for about 6 years now. Any issues with removing it? What do I do with the holes that were drilled for the front mounting points? And the weatherstripping that had to be cut during original install?
Chilow is offline   Reply With QuoteReply With Quote
Old 05-19-2024, 12:24 AM #2
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
To cover up the holes from where the rack was attached, you can use rubber plugs for cars. They'll close the holes well and keep out water and dirt. Or, if you plan to install something else later, you can leave the holes open for now, but it's better to seal them temporarily to stop rust.
Replace the weatherstripping that got cut when the rack was installed to keep a proper seal and prevent wind noise or water leaks.
After you take off the rack, check the roof for any damage. You can clean and wax it to protect the paint.
weberlukas74 is offline   Reply With QuoteReply With Quote
Old 05-19-2024, 01:42 PM #3
use shorter bolts in the front rivnuts you installed and rtv them. Or just goober the hole with rtv. Amazon sells a roof rack delete kit to seal up the OEM mounting points for the other 4 spots. I remove mine every summer. i also no longer use the front spots where prinsu had you drill. i just bolted some rubber legs/bumpers to the front of the rack. it is bulky to do alone. i use some straps and hang it from the carport.
cut weatherstrip is still there. it's meh.
i'm midway through removing mine today. the more accessories/lights/radio antennae you have on it, the more of a hassle it is lol
drill , it’s , prinsu , rack , version
WTB: Prinsu or Prinsu Style Roof Rack for 2003-2009 4Runner smeister Want to Buy/Trade 6 11-23-2022 03:49 AM
Prinsu Full length rack or The 3/4s rack? BradyHankins General Discussions 1 11-16-2021 01:32 AM
Prinsu Snowboard Rack Chilow 5th gen T4Rs 5 03-02-2020 11:05 PM
RTT on a Prinsu rack anyone? PhotogEric 5th gen T4Rs 9 07-29-2018 10:11 AM
Maxtrax on prinsu rack ecr6cyl10 5th gen T4Rs 8 08-05-2017 11:08 PM
