Originally Posted by Chilow
Has anyone removed a ladder? I have a Bajarack ladder that was installed for a few years and I want to remove it. How much of a pain would it be to remove the double sided tape used for mounting? If I were to guess, it’s probably been on for at least 6 years.
dilute some IPA with water in a spray bottle. spray one edge/corner. use a heat gun to heat up the tape. patience. get underneath the tape and pull with steady pressure. don't yank. as you pull, use the spray and heat gun and take your time
if you're struggling still then use pure IPA and don't dilute. wax the area when done. IPA loosens the glue and makes it easy to rub off or peel
