Old 05-22-2024, 12:16 PM #1
sunnah sunnah is offline
sunnah is on a distinguished road
Question Ignition Key Alarm
2017 SR5
Is thre a way to add the ignition key removal alarm if I do not have one? This is the beeping that comes on when the key is in off position reminding the driver to remove it and do not leave the car. My 4runner does not have one and it bothers me a little when it seems to be a simple item they left out that I find in much older cars. Am I able to add this or should I just drop it? Thanks.
sunnah is offline   Reply With QuoteReply With Quote
Old 05-22-2024, 02:25 PM #2
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Originally Posted by sunnah View Post
2017 SR5
It alarms when the driver's door is open and the key is left in the ignition, not just when you turn the car off. It should be there. To test, open the door, then insert the key; it should alarm.
I don't see anything in the settings to turn if off. It it doesn't work, something is wrong.
fkheath is offline   Reply With QuoteReply With Quote
Old 05-22-2024, 08:05 PM #3
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Some cars (not sure if Toyota does this) will lock the doors if the key is left in the ignition for a period of time - running or not - to prevent theft. This happened to a friend with a rental. She started the car and got out to clear snow from the windshield. After a minute or two, the vehicle locked itself.
Also, I have a 2000 Tundra that occasionally locks or unlocks itself whenever it feels like it! Since it's 24 years old, I just carry an extra key!
The key reminder chime might be programmable on or off via techstream. Dealer should know.
Old 05-22-2024, 08:53 PM #4
Toyotas do not do that. But if you unlock the door with the key, then never open a door, the car will assume it may be a stray signal, and then relock the doors after a couple minutes.
Old 05-22-2024, 08:55 PM #5
Most things that can be programmed by Techstream are shown in the owners manual under "Customizable Features". My '18 owners manual does not show that capability.
Old 05-26-2024, 08:28 PM #6
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
You can buy aftermarket kits that you can install. These kits usually come with a small speaker and wiring that connect to your ignition switch.
Or, maybe, check with your local dealership for an original Toyota part or accessory designed for this purpose. Just a thought.
weberlukas74 is offline   Reply With QuoteReply With Quote
add , alarm , ignition , key , left
Emergency Ignition/Headlights Alarm sunnah 5th gen T4Rs 3 12-10-2022 12:49 AM
Avital 5303L Alarm install issue with Remote start triggering alarm. SJC4Runner 4th Gen T4Rs 14 05-21-2017 02:36 AM
New ignition lock cylinder - won't engage ignition - 1996 base CanadaEh 3rd gen T4Rs 2 07-26-2016 03:18 PM
Alarm, Ignition Kill, Strategy bass-o-matic 3rd gen T4Rs 7 08-15-2010 10:30 AM
