Originally Posted by sunnah
2017 SR5
Is thre a way to add the ignition key removal alarm if I do not have one? This is the beeping that comes on when the key is in off position reminding the driver to remove it and do not leave the car. My 4runner does not have one and it bothers me a little when it seems to be a simple item they left out that I find in much older cars. Am I able to add this or should I just drop it? Thanks.
It alarms when the driver's door is open and the key is left in the ignition, not just when you turn the car off. It should be there. To test, open the door, then insert the key; it should alarm.
I don't see anything in the settings to turn if off. It it doesn't work, something is wrong.
