Originally Posted by john_galt
I知 going to be helping a friend do her first oil change in a 2022 Off Road Premium 4R. I have a 2015 SR5. Since she is some distance away, I知 trying to learn if there are any material differences between the vehicles so I can pack my tools and parts. I致e used the Antman guide on my vehicle.
Assumptions: Filter: 04152-YZZA5, Crush washer 90430-12031
I have this 64mm filter wrench - Motiv MX2320. For some reason they only list 4R compatibility as 2010-2021 on Amazon. Is this the correct filter wrench?
On my 15 SR5, the lower filter housing was plastic. Is the ORP filter housing also plastic? Has anyone replaced it with the Aluminum one (#15620-31060)?
Thanks
Since your friend has an Off Road Premium, they are likely to have the TRD skid plate. That must be removed to do oil changes. It can be a challenge to line up when reinstalling. Thus, many people have replaced the mounting bolts with studs which makes it so much easier to reinstall.
Because it is so hard to line up the skid plate while trying to get the bolts started, many people, including the dealer, often strip the threads.
