Old 05-28-2024, 07:04 AM #1
Mr_Dobalina Mr_Dobalina is offline
Mr_Dobalina will become famous soon enough
2019 Driver side condensent issue from AC
I just recently started using my AC this year and a new problem has developed.
I get water pooling on the drivers side front mat. Any ideas on how to address? I have never had this problem in the past.
Mr_Dobalina is offline   Reply With QuoteReply With Quote
Old 05-28-2024, 08:13 AM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Possible clogged AC condensation drain hose?
2004 Limited V8
Old 05-31-2024, 10:06 AM #3
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
First, maybe, try clearing your AC drain tube. Use compressed air or a flexible wire to remove any blockages. Then, check the drain hose.
If that doesn't help, check the AC evaporator case for leaks. Sometimes, leaks can cause water to get into the cabin.
weberlukas74 is offline   Reply With QuoteReply With Quote
Old 06-01-2024, 07:49 AM #4
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Leaking water under the dash area
AC is pouring water in the car as we drive.
Leak help
A/c drain mod
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
drivers , front , mat , problem , side
Driver side brake light ground issue 4Runner@504 4th Gen T4Rs 5 05-16-2023 06:46 PM
2018 & 2019 TRD Off-Road front spring paint mark differences Passenger / Driver side Seymore Butts 5th gen T4Rs 0 05-31-2019 09:52 AM
Driver side front and rear lower than passenger side! gyro09 3rd gen T4Rs 3 07-14-2016 04:21 PM
Front Driver's Side Strut Issue mshaner152 4th Gen T4Rs 29 04-12-2012 10:42 AM
Driver side versus Passenger side front coil heights terrytcl 3rd gen T4Rs 5 02-28-2012 07:06 PM
