Old 05-29-2024, 04:41 PM #1
Soneill's Avatar
Soneill Soneill is offline
Soneill will become famous soon enough
Soneill's Avatar
Shrockworks turn signal wiring
The Shrockworks bumper comes with a 3 wire harness with 1157 bulbs, and the factory harness is 2 wire. I've had the turn signals running off the 2 wires from the factory without issues. but now i have a set of amber to white switch back bulbs and was wondering if it possible to wire it up to function correctly using the 3 wires from the Shrockworks bumper the the factory 2 wire. Right now the white wire from the 3 wire on the bumpers doesn't go to anything. When plug it in the the hot wire both amber and white light up. Any help would be appreciated.
2011 SR5 4x4, Toytec Ultimate w/ SPC UCA's, Shrockworks Front Bumper, 285/70/17 BFG KO2, NFAB Steps
Soneill is offline   Reply With QuoteReply With Quote
Old 05-29-2024, 09:05 PM #2
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
I gather your new bumper didn't come with an electrical diagram - seems like it should have. An 1157 is a dual filament bulb; so the 3 wire harness is probably a power wire for each filament of the 1157 bulb and a ground. You can verify this with a meter; and also verify what what you're getting from the factory harness and then connect things up the way you want.
Old 05-31-2024, 09:23 AM #3
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
The 1157 bulbs are dual-filament: one filament for the running lights (which usually uses a lower power) and one for the turn signals (which uses a higher power). That's why the Shrockworks harness has 3 wires: ground, running light, and turn signal.
Since your factory harness only has 2 wires, it was likely designed to combine the functions or support only one. Here's what you can do:
1. Figure out which wire on your factory harness is the ground and which is for the turn signal.
2. Attach the ground wire from the Shrockworks harness (usually black) to the ground on your factory harness.
3. Attach the turn signal wire from the Shrockworks harness (often red or yellow) to the hot wire on your factory harness.
4. Connect the running light wire from the Shrockworks harness (usually white) to a new power source that turns on with your running lights, possibly splicing it from another running light wire on your vehicle.
weberlukas74 is offline   Reply With QuoteReply With Quote
Old 05-31-2024, 01:21 PM #4
Soneill's Avatar
Soneill's Avatar
I figured it was going to be something like this. I found out the factory turn/running light is an 1156.
I was hoping not to have to run extra wires, but it is what it is.
factory , shrockworks , white , wire , wires
Turn Signal/DRL wiring 4wordSOUL 4th Gen T4Rs 0 07-12-2023 07:32 PM
Turn Signal Wiring - Help Please On Point 5th gen T4Rs 17 01-28-2022 01:16 PM
FS:Brand new Hella DRL/Turn signal for shrockworks bumper Keemonrunnin For Sale: Non-T4R Items 4 11-19-2013 01:07 PM
Shrockworks replacement turn signal macoyle 4th Gen T4Rs 3 07-16-2012 11:34 PM
