Old 06-15-2024, 04:38 PM #1
DarthYota's Avatar
DarthYota DarthYota is offline
DarthYota is on a distinguished road
DarthYota's Avatar
HELP - Big ol FML - Sheared Caliper Bolt - Part identification
Set out to replace my brakes today including calipers and ss lines.
Started on the front right, got the rubber line converted to ss. btw - the rubber plugs that come with the stop tech lines dont seem to really stop the dripping, just slow it. Nor are they caps that go on the hard line.
Next I went to the bottom 17mm holding the caliper to the (unknown part) steering knuckle? hub? and it was pretty tight. Gave my 3/4 in drive a couple of whacks with a rubber mallet since I dont have a true breaker bar.
bolt sheared in half.
FML and 50k other expletives.
need to ID the part number the calipers bolt to and see if I can replace it myself or continue doing what I can and have it towed to a shop.
I'm searching the interwebs but figured this might be faster. Any help id'ing is appreciated.
2014 LE - Attitude Black w/Redwood - MODS - Status Mastadon 20x9+5 Carbon Graphite w/Yokohama G015 275/55/20, TRD Pro Front End, RCI Aluminum Skids Bumper-Trans, Rhino-Rack Pioneer 76x49 Backbone System (Chopped to 68x49), GTR Carbide LED Headlamps, DD SS3 MAX Amber Fogs, Gibson Catback Side Exit Dual Tip Black Ceramic Exhaust, Tint: 20% Front/%35 Rear/Limo sunroof, Black Door Handle Covers -
DarthYota is offline   Reply With QuoteReply With Quote
Old 06-15-2024, 05:34 PM #2
DarthYota's Avatar
DarthYota's Avatar
think i found the right part...
https://parts.lakelandtoyota.com/p/T...321160200.html
anyone want to speculate on the chances of using a bolt extractor to get that bolt out? ...so I dont have to replace the steering knuckle.
Old 06-15-2024, 08:32 PM #3
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
It shouldn't be that hard to drill the broken bolt with progressively larger bits until only a thin portion of the threaded section remains at which point should be easily removable, afterwards you may have to use a tap to clean up the threads.
Very much worth trying instead of buying another knuckle and paying to have it installed!!
2004 Limited V8
Old 06-17-2024, 02:46 PM #4
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Is the bolt broken below the surface or is it exposed?
Best Regards,
Saker
2021 T4R *MIDNIGHT BLACK METALLIC* TRD OFF ROAD PREMIUM 4X4| Saker’s Ebony Build | Saker’s Previous 2014 Midnight Build | Scuba Mod| Scuba Mod w/ Locker | LED LIGHT BAR INSTALL | Saker's EBRs Photos Updated 05-21-16| Saker's Previous 2013 FJ TT/SE
Old 06-23-2024, 05:22 PM #5
DarthYota's Avatar
DarthYota's Avatar
it's exposed but barely a nub...not enough to grip with visegrips.
Old 06-23-2024, 05:25 PM #6
DarthYota's Avatar
DarthYota's Avatar
i bought a bolt extractor kit from lowes...
between the bolt not steering off flat and all of the suspension and steering linkage in the way, I couldn't get a flat seat with a standard drill and bit.
rather than F it up more I finished the brake job and just dropped it at the mechanics to see if they can extract it. if not they'll drill and tap it. and if that doesn't work a new steering knuckle will be in my future.
Old 06-24-2024, 02:20 PM #7
Offroad Alliance Offroad Alliance is offline
official vendor
Offroad Alliance is on a distinguished road
official vendor
Drill the bottom out progressively and it should come out. Them spindles arent cheap and thats a lenghty swap time.
For reference, you said you were using a 3/4 drive?
Offroad Alliance is offline   Reply With QuoteReply With Quote
Old 06-24-2024, 02:45 PM #8
03_4x4Runner's Avatar
03_4x4Runner 03_4x4Runner is offline
03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about
The saying goes "We wrench not because it is easy but because we thought it would be easy".
03_4x4Runner is offline   Reply With QuoteReply With Quote
Old 06-24-2024, 10:07 PM #9
CutthroatSlam CutthroatSlam is offline
CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of
First soak for a day with PB Blaster or 50/50 mix of ATF and Acetone. Then hit it good with a mapp gas torch before attempting to break it loose.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 06-25-2024, 07:25 AM #10
osugsxr osugsxr is offline
debated changing the rear brakes this past weekend. I watched a few videos and read this as well, the breaker bar did the job for me. I initially sprayed all bolts with pb blaster and then used the breaker bar. I enjoyed projects when they go smooth but always one bolt away from a 30-45 minute job into an all day issue. Could probably have used an impact wrench too
Old 06-25-2024, 09:19 AM #11
djeepin djeepin is offline
djeepin is on a distinguished road
That's why I love this forum: hugely entertaining:
2014 LE - Attitude Black w/Redwood - MODS - Status Mastadon 20x9+5 Carbon Graphite w/Yokohama G015 275/55/20, TRD Pro Front End, RCI Aluminum Skids Bumper-Trans, Rhino-Rack Pioneer 76x49 Backbone System (Chopped to 68x49), GTR Carbide LED Headlamps, DD SS3 MAX Amber Fogs, Gibson Catback Side Exit Dual Tip Black Ceramic Exhaust, Tint: 20% Front/%35 Rear/Limo sunroof, Black Door Handle Covers >>>
djeepin is offline   Reply With QuoteReply With Quote
bolt , line , part , rubber , stop
Urgent - need part # front caliper bolt TerpRunner 5th gen T4Rs 4 01-12-2022 01:59 PM
Alternator adjustment bolt sheared off crespoh69 3rd gen T4Rs 5 11-14-2020 10:37 PM
Sheared Lug Nut Bolt cgarrett5119 4th Gen T4Rs 8 05-05-2014 11:52 PM
Sheared off U-bolt mechagouki Classic T4Rs 9 10-01-2012 06:41 PM
LBJ Bolt Sheared Off... fish0281 3rd gen T4Rs 10 08-01-2012 06:39 PM
