Old 06-17-2024, 11:58 AM #1
paczowski123 paczowski123 is offline
paczowski123 is on a distinguished road
Oil cannister drain
Perhaps I am doing something wrong, but what is the point of the drain on the bottom of the oil filter cannister if it does not drain the housing? I use Toyota filters as they are a third of the cost of aftermarket and they come with all O-rings plus the plastic drain insert. BUT, only a small amount of oil actually seems to drain, then when I use the socket to unscrew the cannister a TON more oil drains out? Why would it not fully drain the housing? It ends up covering my socket, hands, housing, tools etc in oil, which is not a HUGE deal to clean off with some brake clean, but why would there even be a drain if it does so little? Am I doing something wrong?
paczowski123 is offline   Reply With QuoteReply With Quote
Old 06-17-2024, 12:09 PM #2
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
I copied this from a great write up from @Antman for an oil change.
This part stops the big flow you are getting.
Once the oil has stopped dripping, push the plug to the side to pull it off. This part is neat- toyota designed the plug to pull the old O-ring off with it! Kinda cool the way they did that. Both of these parts are trash. It's Ok, throw them away.
Oil Change 5th Gen: How To- LOTS of PICS!
BobsTrail is offline   Reply With QuoteReply With Quote
Old 06-17-2024, 01:01 PM #3
osugsxr osugsxr is offline
i may have used that once it the past 3 years. I just take the housing off and clean up the mess not much though.
Old 06-17-2024, 03:54 PM #4
Thanks! That is pretty much the same process I follow. However my main question was why so much additional oil spills around the oil filter housing AFTER using the drain. Seems pointless to even use it if you're still going to have the housing still leak, might as well save a step and just drain it straight from the housing when removing.
Old 06-18-2024, 10:43 AM #5
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
The spring is super tight and very hard to get to drain with those plastic nipples. I use this and it drains all the oil out, works great
https://www.amazon.com/Motivx-Tools-...ps%2C87&sr=8-7
cannister , drain , housing , oil , socket
Evap Charcoal Cannister vacuum line recommendation Doc3g 3rd gen T4Rs 7 01-15-2021 08:45 PM
4runner oil cannister olhobbler 3rd gen T4Rs 5 04-10-2019 08:37 AM
Fuel Leak... Charcoal Cannister? ad1315 Classic T4Rs 8 01-25-2013 08:17 PM
'06 Evap Pump/Charcoal Cannister Replacement? dipNrip Problems & Warranty Issues 0 01-02-2011 08:34 PM
Charcoal cannister VSV lstall 3rd gen T4Rs 3 05-18-2008 04:15 PM
