Old 06-20-2024, 03:55 PM #1
zzdocxx zzdocxx is offline
zzdocxx is on a distinguished road
Can't Control Back Windows from Driver's
The back windows work OK using the controls in the back seats.
But I can't open and close them from the driver's seat. (You know, there are four levers there, two front two back.)
The front windows open just fine from the driver's seat.
I just discovered this yesterday, but I have been working out of town and rarely home the last couple of years.
(Of note, last month I had to get a jump from AAA at my house because my battery had gone dead. I can't remember if I even got a click from the starter but definitely no engine turnover at all. I can't remember if I left an interior light on or something ? So I don't know if that might have anything to do with it or not.)
I think Toyotas are well-known for window switch problems, however, last time I had this, on my Pre-runner, an engineer friend said to spray it with LPS electrical contact lubricant (LPS 1) and that did the trick.
I called my regular mechanic and they said it sounds like the master switch. It sounds expensive.
Any thoughts on this ?
Thanks everyone, I love this forum, the generosity with your time and help is so very much appreciated by me, and by many others.
PS, edit: I found this yt vid having to do with "normalizing" power windows, moonroof, etc., after disconnecting the battery for --not sure, more than just a few minutes?
https://youtu.be/zXAEQN7yegA?si=tG31frPvtHND2PKG
PSS: the vid above seems to be about getting the "auto" function of the windows to work, which is when you push the lever once and the window goes all the way down, or up too I guess. I just noticed that the front four switches in the driver's door say "All Auto" underneath them. Also that the back door window switches say "Auto". But the back windows are not doing the "Auto" thing. I played around with holding the switch down for a few seconds extra but no love on that. Ai yi yi looks like I'm in for an expensive visit to the shop.
Driver door switches still not opening back windows.
2017 TRD Off Road
zzdocxx is offline   Reply With QuoteReply With Quote
Old 06-20-2024, 04:14 PM #2
spartacus's Avatar
spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of
spartacus's Avatar
Start by checking the fuses just in case the AAA guy arced the battery.
Old 06-20-2024, 04:17 PM #3
jdm-v35 jdm-v35 is online now
jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough
Thanks everyone, I love this forum, the generosity with your time and help is so very much appreciated by me, and by many, many others.
Did the "window switch lock" button accidentally get pressed?
2018 TRD ORP w/ Magnuson
jdm-v35 is online now   Reply With QuoteReply With Quote
Old 06-20-2024, 04:20 PM #4
OK will do that now.
Checked that, all in order.
Thanks for the suggestions.
2017 TRD Off Road
Old 06-20-2024, 05:18 PM #5
Looks like the fuses are OK, though to be honest:
1. I'm not sure which fuses control the windows. I looked for some info but just found it for the old secondary interior fuse boxes below and to the left of the steering wheel.
2. I think I would have to take out each fuse to be able to inspect it for failure, would I not? I don't suppose they have been thoughtful enough to build them such that failure would be detectable while the fuse is in place.
3. I did find the relay box, three big relays in there, not sure how to detect failure.
I sprayed some LPS 1 in where the switches are, just on the off-chance, but no.
I don't like all the time it takes to take the 4R over to the shop and wait for it.
OK I am going to try this again https://youtu.be/K_AGepBE9Is?si=X-XP5sixc6p-l46A but not right now, time for a break!
2017 TRD Off Road
Old 06-20-2024, 07:15 PM #6
MasterFoo MasterFoo is offline
MasterFoo will become famous soon enough
Your battery went dead, possibly need to reset your windows
MasterFoo is offline   Reply With QuoteReply With Quote
Old 06-20-2024, 11:54 PM #7
That's what I am thinking.
Because in that second vid, it was the same situation I had. Ie. that the back windows would roll down from the back seat controls, but not from the driver's door.
Prob get to that tomorrow.
Thanks again everyone.
2017 TRD Off Road
Old 06-21-2024, 09:10 AM #8
Humble Leader's Avatar
Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold
here's an idea you might be able to try. the door panel is fairly straightforward to remove. you don't even need to pull it off completely, I'm wondering if you could swap the plug from one of the rear window switches to the front switches. that way if the front window switch rolls the rears down then it's the switch itself and you can replace that whole switch assembly
I don't think there's an issue switching the plugs like this since the motor I believe is the same for all windows. if the fuses are OK then it's either a computer issue, wiring issue or switch issue. the first two are complex to solve the third is just a swap out
Old 06-21-2024, 09:48 AM #9
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
That won't work because the the drivers window switch is a module with a single connector, not four separate switches with four connectors.
fkheath is offline   Reply With QuoteReply With Quote
Old 06-21-2024, 10:20 AM #10
Well that's a relief, I was afraid that Humble leader had me in for a few hours work. I realize that it might take others just 15 minutes to do the same job but just saying !
So as of now the plan is to do that up and down and hold thing with the back windows, see if they will reset. The second video showed that he had to do it like five times before it took.
2017 TRD Off Road
Old 06-21-2024, 02:12 PM #11
damn. I guess you could try a new assembly with all four switches. you could order OEM from a dealer and pay the restocking fee if it doesn't solve the problem.
I've had toyota/lexus vehicles for years and numerous dead batteries, even unhooked batteries for days and never had to reset my windows. why do some people have to reset and others dont?
Old 06-21-2024, 10:59 PM #12
I bought a used drivers door switch off Ebay because I had broken the mounting bezel for the switch. It came a bit corroded (must have been out in the rain at a junk yard), but all I needed was the bezel, so put my original switch in it.
You might look on Ebay for a used switch.
back , drivers , remember , seat , windows
Extending Driver's Seat Back For Tall Driver jtroop 3rd gen T4Rs 28 03-08-2021 09:03 PM
Passenger and Driver side windows 2004 4R Dergibog 4th Gen T4Rs 0 05-18-2020 09:48 AM
Driver side windows rolled down on their own drbax 5th gen T4Rs 1 12-29-2015 11:02 PM
power windows / door locks / chairs control / sunroof / back window stopped working Magiclamp2012 3rd gen T4Rs 5 09-08-2014 09:43 AM
