Old 06-28-2024, 04:14 PM #16
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
Bigger muffler or add a resonator
Old 06-28-2024, 11:28 PM #17
1100 Remington Man's Avatar
1100 Remington Man 1100 Remington Man is offline
1100 Remington Man is on a distinguished road
I have a 2022 TRD Pro and it does not bother Me but I only have 22,000 miles.
1100 Remington Man is offline   Reply With QuoteReply With Quote
Old 06-29-2024, 02:04 PM #18
FourT6and2 FourT6and2 is offline
FourT6and2 is on a distinguished road
I've got 60k miles on my '21 TRD Pro and yeah... the exhaust is annoying as hell. Can barely have a conversation with a passenger while on the highway. Toyota designers are not winning any points with this monstrosity.
FourT6and2 is offline   Reply With QuoteReply With Quote
Old 07-20-2024, 03:29 PM #19
Nikko's Avatar
Nikko Nikko is online now
Nikko is on a distinguished road
Nikko's Avatar
Can just the muffler be swapped with the normal 4Runner muffler and retain the look of the Pro? Seems like it would just be a flange to flange swap?
I have 45K on mine and it’s very annoying for sure.
2021 TRDP
Nikko is online now   Reply With QuoteReply With Quote
Old 07-20-2024, 07:22 PM #20
ejesauer ejesauer is offline
ejesauer is on a distinguished road
The flanges for the mid-section are different between the normal exhaust and the trd pro catback exhaust. The normal one is a 2 hole design and the trd pro is a three hole design. There is no plug and play solution for it that I have ever found. Basically your option is to replace it with another exhaust that has the proper 3 hole mid-section, which is usually some sort of other brand of performance exhaust, or have a muffler shop cut off one flange and weld on the proper one. The muffler shop option would probably be the least expensive option especially if you can find a used OEM exhaust someone wants to get rid of.
ejesauer is offline   Reply With QuoteReply With Quote
Old 07-20-2024, 09:24 PM #21
FZRunner FZRunner is offline
Real Name: Greg
FZRunner will become famous soon enough
Real Name: Greg
I put a magnaflow overland on my pro. Got it for a couple hundred off retail, had one on a previous orp. It’s definitely got some noise, but it’s not a drone. Arguing about trim levels is a little childish. Get what you like, and be happy for others choices too. We’re all a 4runner family folks.
FZRunner is offline   Reply With QuoteReply With Quote
Old 07-21-2024, 11:58 AM #22
Nikko's Avatar
Nikko's Avatar
That’s unfortunate that it’s not just a plug and play with the normal 4R muffler. Exhaust shop by me says they can do one that drops right in made by Walker? I don’t know much about them and I’m just worried that it won’t solve my problem. Flip side is, I would prefer not to have anything cut up if I don’t have to.
2021 TRDP
Old 07-21-2024, 02:00 PM #23
After looking at it again, I think the flanges should still fit on the cat side, so yes they should have a drop in that will work on the cat side. The 3 hole flange is on the midpipe, so they should be able to just weld a 2 hole flange on the tailpipe if you want to keep your tailpipe with the chrome tip, which is no big deal. As far as solving your problem if drone, yes, a Walker Quiet Flow will be quiet and not sound anything like the TRD exhaust. We just put one of these on my son's 2003 Xterra and it is quiet. They are cheap and my not last the longest, but they are serviceable and work.
Old 07-24-2024, 02:14 PM #24
bowhun2r's Avatar
bowhun2r bowhun2r is offline
bowhun2r will become famous soon enough bowhun2r will become famous soon enough
bowhun2r's Avatar
This was my solution... The drone was just too much for me. Took off the TRD Pro exhaust and put on the OEM.
You will also need the tail pipe to muffler gasket since the TRD Pro exhaust does not use it. Optionally, I also got the gasket donut gasket for the front part of the muffler. The spring bolts connecting the muffler are re-used.
Non TRD Pro Exhaust #: 17420-31360
Non TRD tail pipe #: 17430-31870
Gasket for the front of the muffler: 90917-A6001 (you might be able to use existing)
Gasket for tail pipe to muffler: 17451-31020 (you need this since the TRD Pro exhaust does not have this)
Unfortunately, I do not have the part #s for the two bolts for the tail pipe assembly to the muffler. The TRD Pro exhaust uses 3 bolts compared to the non TRD Pro tail pipe.
Currently I have it listed on Craigslist for 250 bucks...
Quiet down 2024 TRD Pro Exhaust?-img_9289-jpg
24 PRO: Maggy S/C | SB Street 4| Michelin LTX AT2 | DD LED Interior and Tail as Turn | Trail edition Running Boards | Rago Molle panels | CanvasBack Liners | Alea Leather Seats
Sold 18 LE: Magnuson S/C| FN PRO Wheels| Diode Dynamics HID LB| Tail as turn LED| XD DRL/LB LED | Precision LED interior | Cooper AT34S 265/70/17 | Trail Rocker and Running Boards| 12.volt Solutions RS | Canvasback liners | Dobinsons 300/700 599/705 10mm spacer | ILX-207 Alpine PDR-F50 | Rago Molle panels | Pro grill with LED | Pro bumper swap | RCI skids
bowhun2r is offline   Reply With QuoteReply With Quote
Old 07-28-2024, 07:36 AM #25
Nikko's Avatar
Nikko's Avatar
Appreciate the help. That seems to be the best solution at the moment.
2021 TRDP
Old 07-29-2024, 06:11 AM #26
RRosco RRosco is offline
RRosco is on a distinguished road
Had a drone issue on my Lexus when I customized the exhaust. I installed a J-pipe. The length can be adjusted depending on what RPM the drone is.
RRosco is offline   Reply With QuoteReply With Quote
exhaust , exit , pro , side , trd
Walker Quiet-Flow Exhaust? coinball 3rd gen T4Rs 7 03-28-2015 08:51 AM
Quiet the Engine Bay, to be able to make exhaust more noticialbe 1998Yota4Runner 3rd gen T4Rs 9 09-16-2014 01:14 PM
My exhaust is too quiet coreyray7 4th Gen T4Rs 43 10-06-2013 01:21 PM
Have an 06 4.0 w/TRD exhaust, How do I quiet it down?? Dunk50 Engines / Suspension / Wheels / Tires / Audio / Accessories 1 10-04-2011 10:00 PM
TRD Exhaust To quiet??? AK602 Engines / Suspension / Wheels / Tires / Audio / Accessories 8 06-25-2008 06:38 PM
