Old 06-29-2024, 09:33 AM #1
NYRunner NYRunner is offline
NYRunner will become famous soon enough
Back door window motor replacement- any tips or info on how-to would be appreciated
My driver side rear door power window started moving slowly and then stopped working a few years ago, and life and a couple of surgeries got in the way of my fixing the problem. Fortunately it was closed when it stopped working the very last time.
One of the things I did try was to spray down the motor inside of the door with De-oxit spray to no avai
Somehow last week I accidentally hit that button and the window was working perfectly again, at regular speed, and all the way up and down. I thought I must’ve hit the jackpot and the spray must’ve soaked in and worked.
Unfortunately it froze again and stopped working with the window down a few inches, so I’ve ordered a replacement motor which will arrive on Monday.
Questions:
Being that it started working again and then stopped, is there anything I should check that may be causing this other than the motor?
If I have to replace the motor, being that it’s on the inside of the door and not easy to see what’s going on, how do I remove and reinstall the glass without breaking it and making sure eveything is lined up correctly?
Any tips would be greatly appreciated! And if anyone on Long Island or in Connecticut or central to northern NJ would be willing to help I’ll be more than happy to supply the beer and sous vide us some steaks or make some killer gumbo or anything else as I’m a hobby chef and pretty darned good one at that!
Thanks in advance
2010 Mag Grey Limited 4X4
NYRunner is offline   Reply With QuoteReply With Quote
Old 06-29-2024, 10:03 AM #2
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Questions:
Thanks in advance
It may not be the motor, but the “linkage”. Lubricate all the joints and tracks.
Deoxit is the wrong stuff to use; it is for electrical connectors, not mechanical joints. Better to use SeaFoam Deep creep, or just WD40.
fkheath is offline   Reply With QuoteReply With Quote
Old 06-29-2024, 10:11 AM #3
Thanks @fkheath !
It isn’t budging or making any noise like it would if it was trying to move. I tried de-oxit on the motor, connectors and switches in hopes that was the cause
If I spray WD40 in there in hopes of not having to replace it, could that negatively affect the motor?
Old 06-29-2024, 10:26 PM #4
Don’t use WD40 on the motor. Use it on the joints and linkage.
door , motor , stopped , window , working
Tailgate / back window doesn't work (motor works and it isn't the window lock switch) seattlee 3rd gen T4Rs 17 04-03-2022 08:58 PM
Tips & tricks for cleaning window/door trim? MONTYMTB Maintenance/Detailing 3 06-05-2013 05:03 PM
Door Window Motor replacement quatin 3rd gen T4Rs 11 10-01-2012 11:34 PM
Replacing motor on the back window hulk311 3rd gen T4Rs 3 11-13-2011 04:18 PM
Buyer Info-2ndGen-22Re. Any info greatly appreciated Joel 4th Gen T4Rs 8 02-12-2005 05:17 AM
