Old 07-16-2024, 07:23 PM #1
Forestphile Forestphile is offline
Forestphile is on a distinguished road
Water in liftgate
Hello!
I've got a 2016 sr5 that's got water (lots) accumulating inside the liftgate after it rains. I'm nervous about the electrical components inside the liftgate getting damaged.
After looking around the threads here, it seems like its probably the weatherstripping across the bottom rear glass.
That's the first thing I'm going to try to replace; I was just hoping someone could point me in the direction of a part number for it. I've searched various threads here- but all seem to be for 4th gens for this particular repair.
I think it's #68292-35041, but just wanted to double check. Also open to other thoughts if there's something else I should be checking.
Forestphile is offline   Reply With QuoteReply With Quote
Old 07-16-2024, 09:23 PM #2
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Originally Posted by Forestphile View Post
Hello!
Some water will always get past the weather strip at the bottom of the window. If you have a lot of water in the tail gate, it is not due to the weather strip, but rather due to the drains at the bottom of the door. Your drains are clogged. Clean them out so the water will drain out. If you open the hatch, you can easily see the three drains at the bottom.
Your biggest worry should not be electrical, but rather rust. See:Rear Window Went Crunch- Need Help!
fkheath is offline   Reply With QuoteReply With Quote
Old 07-16-2024, 10:28 PM #3
Tooly Tooly is offline
Tooly is on a distinguished road
You can actually pop out the black plastic hand holds and then reach in and wipe the grime out or blow it out. I had to after a recent trip to Utah where a lot of dust got in there with all the dirt road driving.
2024 4Runner ORP - Canada Spec
1989 Land Cruiser BJ74 - Sold
1986 Land Cruiser BJ70 - Rusted Away
Tooly is offline   Reply With QuoteReply With Quote
Old 07-17-2024, 10:02 AM #4
Heavy_GD's Avatar
Heavy_GD Heavy_GD is offline
Real Name: GD
Heavy_GD has a spectacular aura about Heavy_GD has a spectacular aura about
Heavy_GD's Avatar
Real Name: GD
I'm thankful that you decided to make a new thread after commenting in the other threads
Water In the Tailgate/Rear Hatch
Lift Gate area rust
You should post a video of your resolution
'24 TRD Premium
Heavy_GD is offline   Reply With QuoteReply With Quote
Old 07-17-2024, 02:47 PM #5
Thanks, unfortunately it's not "some" water, it's a lot. Multiple quarts after each time it rains.
I'll definitely check out the drains too and clear them.
Old 07-17-2024, 02:48 PM #6
Lift Gate area rust
Unfortunately my question wasn't answered there, and the threads were years old. I did try to check out information already on here. 👍
Old 07-17-2024, 02:50 PM #7
I'll give this a go too, thanks!
Old 07-17-2024, 02:50 PM #8
Heavy_GD's Avatar
Real Name: GD
Heavy_GD's Avatar
Real Name: GD
Which is why you should document your adventure for the next person.
'24 TRD Premium
inside , liftgate , number , threads , water
Leak from water inlet/water pump joint - V8 GLP 4th Gen T4Rs 5 01-12-2017 10:52 PM
Engine Whine After Water Water/Mud Exposure - Alternator??? Patton 3rd gen T4Rs 9 05-04-2016 10:42 PM
Salt water/fresh water fishing gear Robmills72 For Sale: Non-T4R Items 0 08-07-2013 12:08 PM
Will a tail pipe draw water if it is barely under water on a boat ramp? jow 4th Gen T4Rs 9 05-08-2013 12:53 PM
Help! New timing belt, water pump, and spark plugs = higher water temps??? vthokie 3rd gen T4Rs 15 05-16-2011 10:59 PM
