Old 08-09-2024, 02:10 PM #16
turneryr turneryr is offline
turneryr is on a distinguished road
Did the same exact thing to my 4runner and I did all the work myself. I am not a mechanic by any means but very mechanically minded (work in engineering). I took out the whole xreas system and replaced them with:
(MONROE 2171371L37270 Quick-Struts w/OE Spectrum Shocks kit
Front and Rear; Except X-REAS Suspension System; w/o Kinetic Dynamic Suspension) from Rock auto. Process was straightforward and easily done over a couple days by myself in my garage. I live in Ohio and this is my daily driver. They have been exellent and I pull my bass boat all over the state with it. Zero issues.
Sorry. its a 2010 limited.
turneryr is offline   Reply With QuoteReply With Quote
Old 02-03-2025, 01:29 PM #17
saba1418's Avatar
saba1418 saba1418 is offline
saba1418 is on a distinguished road
saba1418's Avatar
@patrickdotryan
Hello, my 2016 limited has the same issues as your daughters 4Runner did and I was curious how your XREAS delete went, and if the option you chose rides fairly closely to the XREAS did...
(sorry if you posted updates already, I didn't see them if so...)
saba1418 is offline   Reply With QuoteReply With Quote
Old 02-10-2025, 05:15 PM #18
15Limited 15Limited is offline
15Limited is on a distinguished road
I'll be posting about my KYB experience as soon as I can start a new thread. I have no idea how many replies I need for the system to allow me to do that.
2015 Limited
KYB Coilovers & G-Shocks
Michelin Defender LTX MS2
15Limited is offline   Reply With QuoteReply With Quote
Old 02-10-2025, 07:02 PM #19
diehardtacodriver diehardtacodriver is offline
diehardtacodriver is on a distinguished road
shock replacement
its my turn now .. getting rid of the old xres ...how did yours come out...any pictures ??any suggestions on brad to buy?Just keeping it stock or a little lift..thankss for the info..
diehardtacodriver is offline   Reply With QuoteReply With Quote
Old 03-06-2025, 12:05 PM #20
Scuba6's Avatar
Scuba6 Scuba6 is offline
Scuba6 is on a distinguished road
Scuba6's Avatar
Piling on
2011 4Runner w/ factory XREAS. It's been slowly leaking for a while, but it's time to address it. My use case - almost entirely on-road use, based out of NC. Also now towing a 2800lb travel trailer on about a monthly basis.
I have the same question as others recently and want to avoid a new thread on an old topic.
Are Blistein 5100s still the recommended go-to, or is there something new and different I should consider?
@OP - did you end up having to add the new strut mounts you asked about?
2011 Mag Grey Limited Probably not as modded out as yours
War Eagle!
Scuba6 is offline   Reply With QuoteReply With Quote
Old 03-06-2025, 10:05 PM #21
patrickdotryan patrickdotryan is offline
patrickdotryan is on a distinguished road
[QUOTE=saba1418;3852999] @patrickdotryan
Hello,...I was curious how your XREAS delete went, and if the option you chose rides fairly closely to the XREAS did...
Hi Saba and everyone else. Sorry for being a bad forum member, the emails ended up in spam.
Update - I completed the x-reas delete over a weekend by myself with the occasional assist from a kid for things like dropping the skid plate. If you're mechanically inclined it is very easy, really just labor. If you keep your springs, you will need to loan a spring compressor from your local auto store, but it's no big deal.
I opted for the Bilstein 5100 shocks all round, and kept the existing springs. 4WD shops want you to get much beefier shocks (like 6112s up front), but Bilstein recommends the 4600s as an option, so the 5100s are already a high quality step up from those for a mostly road-going truck. There is ride height adjustment on the fronts, but I opted for the stock position, since my daughter is short! I thought I posted a how-to, but clearly not!
Ride-wise, the 5100s are fantastic. The truck feels like it rides better than it did before, and my x-reas was only weeping a bit, so I'm assuming I had close to the original ride feel before the swap out. I was worried about "brake dive", but there doesn't seem to be any of that. Likewise body roll, that seems about the same. Overall, I'm extremely happy, it feels like a new truck.
A few notes:
@Scuba6 you should get new spring mounts as the rubber part that the spring sits in up top will have a deep spring impression. They're cheap and contribute to ride feel.
The top nut on the rear shocks cannot be reached by a torque wrench, so you'll have to guesstimate that one. Everything else can though.
Removing all the old pipes etc is a lot of the labor, but for me, I didn't want to leave all that old junk on the truck. I wanted it to feel crispy new like it cam from the factory with SR5 suspension.
Overall?
Very happy I did it. Replacing x-reas at the dealer with new x-reas is like a $6,000 ding. Getting a 4WD center to replace with 6112 front / 5100 rear was about $2,500. This whole deal was about $600 in parts and a pretty easy weekend job for a whole "new truck feel".
(old) My daughter’s 1998 4Runner Limited, 2WD
180k miles
(new) My daughter’s 2015 4Runner Limited 4WD
113k miles
patrickdotryan is offline   Reply With QuoteReply With Quote
Old 03-06-2025, 10:17 PM #22
Originally Posted by saba1418 View Post
@patrickdotryan
Sorry @saba1418 - I messed up the quote above so you may not get the notification. Hopefully this fixes it.
Another thing I thought of. While I had it all apart I replaced the sway bar end links and a ton of little plastic plugs in the plastic skid plate splash guard and some missing rubber fender splash guards too. Not needed, just worth spend a small amount more while doing all that labor.
180k miles
113k miles
Old 03-06-2025, 10:54 PM #23
OK, hopefully this works, here are some of my photos, including the spring compression and the difficult to reach (with a torque wrench) rear top nut.
5th Gen LImited x-reas delete for road use-img_4808-small-jpg  5th Gen LImited x-reas delete for road use-img_4809-small-jpg  5th Gen LImited x-reas delete for road use-img_4815-small-jpg  5th Gen LImited x-reas delete for road use-img_4818-small-jpg  5th Gen LImited x-reas delete for road use-img_4819-small-jpg  5th Gen LImited x-reas delete for road use-img_4826-small-jpg  5th Gen LImited x-reas delete for road use-img_4823-small-jpg  5th Gen LImited x-reas delete for road use-img_4828-small-jpg
180k miles
113k miles
Old 03-07-2025, 09:12 AM #24
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
My only suggestion, after have done it 2 or 3 times, is to forget about a spring compressor and use the floor jack under the lower control arm to compress the spring, remove the single top nut securing the front shock and the spring and shock come out disassembled. Reassembly is just the reverse procedure. Saves a lot of time with spring compressor and possible danger.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 03-07-2025, 03:48 PM #25
Great tip, thanks @rdruss . That would for sure be faster. I took the springs out for the following reasons:
  • I wanted to replace the upper rubber spring mounts as they wear out and replacing them really helps ride quality.
  • I also wanted to see if the springs were worn out, and if not, to fully degrease them and the surrounding area because leaking x-reas creates a mess.
  • Using a good spring compressor is pretty simple and safe as long as the right precautions are taken. I used a ratchet strap (not shown in photo!) to my workbench so if it slipped, it had limited scope to travel.
Thanks everyone for sharing - these tips can only make it easier for the next DIYer!
180k miles
113k miles
Old 03-08-2025, 11:03 AM #26
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Modern springs don't "wear out". In the old days (1950s to 1970s) springs would sag, but not now.
fkheath is offline   Reply With QuoteReply With Quote
Old 03-10-2025, 11:17 AM #27
Scuba6's Avatar
Scuba6's Avatar
Overall?
Thank you, this is all very helpful!
I spent the morning driving to a few different mechanics in the area that neighbors recommended and should have some quotes back this afternoon. Although your description and the various youtube videos on the topic make me confident that I COULD do it...this may be one that I need to let the professionals do if the price is fair. Guess I'll know if anyone is "fair" this afternoon.
War Eagle!
front , limited , ride , springs , x-reas
Opt off-road cam tab delete review aemravan 4th Gen T4Rs 4 06-15-2022 06:17 PM
Helping out a buddy..2015 w/X-REAS..delete? Vwright14 5th gen T4Rs 23 08-25-2021 06:28 PM
Need a shop in FL to Install Icon, delete X-REAS? UFG8R Runner 5th gen T4Rs 12 07-11-2012 09:04 PM
Rocky Road Non-TE Sliders and X-REAS kingpin748 5th gen T4Rs 17 06-01-2011 04:13 PM
X-REAS on the Limited... dbrotto 4th Gen T4Rs 13 03-31-2007 01:13 PM
