Old 07-29-2024, 07:16 PM #16
TheJokingExplorer TheJokingExplorer is offline
TheJokingExplorer will become famous soon enough
Originally Posted by apc9199 View Post
If that is a metric indicator, your total indicated runout is around .1mm or less than .005". I don't know what factory spec is but I wouldn't let them touch my vehicle over this issue. Get the brakes done and continue to happily drive your vehicle.
According to the 4runner service manual from Toyota. The maximum rear axle shaft runout is 1.50mm and the rear axle flange runout is 0.05mm.
TheJokingExplorer is offline   Reply With QuoteReply With Quote
Old 07-29-2024, 07:21 PM #17
Originally Posted by SocalSam View Post
You know your truck's driving and wear characteristics better than any service ticket writer or grease monkey who test drove around the block. Trust your instincts when dealing with these people.
I agree which is why I'm having a hard time believing that this axle shaft is so out of spec that I need to spend 2k replacing it. Especially since the only symptom is a small squeak hear and there. At the same time I don't want to "assume" I know more than what I really do and then down the line I have an even larger issue.
Old 07-29-2024, 08:52 PM #18
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Do you have any vibration when braking? If the brake disc wobbles too much or is warped, then you will feel a vibration when braking as the pads move back and forth to accommodate the wobble. If you have no vibration, you should be good too go, as others have said about the run out.
fkheath is offline   Reply With QuoteReply With Quote
Old 07-29-2024, 11:19 PM #19
I have no vibration when braking.
Old 07-30-2024, 11:21 AM #20
El Dusty's Avatar
El Dusty El Dusty is online now
El Dusty has a spectacular aura about El Dusty has a spectacular aura about El Dusty has a spectacular aura about
El Dusty's Avatar
There are other options to fix this besides replacing the axle like machining the rotor to account for runout. There are also shims, not sure I would trust them. Both would be more of a bandaid to the actual problem.
To be super clear, your slightly bent axle flange is causing everything mounted to it to also have runout i.e. your rotor and wheel / tire. As your tilted rotor spins it makes the contact surface between the pads and rotor not parallel and dynamic (squeaky). Your wheel & tire are also wobbling although you are not feeling that.
The more runout the more it will reduce your brakes performance, eat up your pads / tires and make noise. We are speculating you are double the allowed.
I think the tolerance is ridiculous and would have thought the caliper could account for some minor misalignment issues but we are talking about high speed rotating parts that need to be parallel to other surfaces to function.
El Dusty is online now   Reply With QuoteReply With Quote
axel , bent , pads , rear , vehicle
What’s your first mod gonna be? Big Country VA New Members 352 04-23-2024 06:04 PM
Lost Registration Package, Temp Tags to Expire. Dealer offered Dealer plate? Pieszeckipower Problems & Warranty Issues 2 09-18-2018 07:16 AM
Well, this is gonna be fun: johnsonnate 3rd gen T4Rs 15 04-05-2017 02:50 AM
I'm gonna do it! Thorgan112 3rd gen T4Rs 13 02-18-2015 04:35 PM
What's my next mod gonna be? fightman80 3rd gen T4Rs 37 11-04-2010 08:58 AM
