Old 07-25-2024, 10:14 PM #1
TheJokingExplorer TheJokingExplorer is offline
TheJokingExplorer will become famous soon enough
How bad is the dealer gonna F me...?
Ive had my 2017 4runner for about seven years never with any problems. A few weeks ago my drivers side rear brake started squeaking only when I would brake. No problem this has happened before just replaced pads and it was back to normal. Normally, I would jut replace the pads myself but I just didn't have time so I dropped it off at Toyota. Next thing I know they send me a link to look at repairs saying my rear axel is bent and it's gonna run about 2k. Vehicle drives fine, no vibration and nothing is leaking. Ive never wrecked the vehicle so idk how the axel would get bent... Anyone have this happen?
TheJokingExplorer is offline   Reply With QuoteReply With Quote
Old 07-26-2024, 09:31 AM #2
MZ2215 MZ2215 is offline
MZ2215 will become famous soon enough
I'd say time for a 2nd opinion. I had my local Toyota dealer tell me they couldn't align my '15 because the cam bolts were froze (despite previous alignments being done twice in the last three years) and that they'd need to cut the lower arms off and replace them at a cost close to $3k. Independent shop had it aligned in 40 minutes.
MZ2215 is offline   Reply With QuoteReply With Quote
Old 07-26-2024, 09:31 AM #3
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Get a second opinion.
Also get specifics. What is actually bent? When people say "axle" they usually mean the tube from the differential to the wheel, but it could also be the axle shaft. Or something else? Have them point to the exact part on the parts diagram.
I've never heard of a 4Runner rear axle getting bent.
Edit: The more I think about this, the more I think something fishy is going on. You go in with just a squeak when braking, which usually means glazed pads, rotors, or parts not lubricated right such as pins where the pads slide. Then they tell you the "axle" is bent and will cost 2K.
fkheath is offline   Reply With QuoteReply With Quote
Old 07-26-2024, 03:57 PM #4
I think they are talking about the axle flange?(correction, it must be the axel shaft) Here is a link to the video Toyota sent me showing the rotor out of alignment.
https://imgur.com/a/6fGPBdi
Old 07-26-2024, 05:22 PM #5
El Dusty's Avatar
El Dusty El Dusty is offline
El Dusty has a spectacular aura about El Dusty has a spectacular aura about El Dusty has a spectacular aura about
El Dusty's Avatar
Thread below should help.
Bent rear axle...are you kidding me?!
Your video shows the axle flange runout being measured which would indicate a bad axel with a bend between the axle shaft and flange. Needs replaced if it exceeds the tolerance.
Are your rear tires wearing weird at all? That would confirm the issue. Since you potentially have a bent flange an alignment wouldn't tell the whole story because as it rotates it would change angle.
Let us know.
El Dusty is offline   Reply With QuoteReply With Quote
Old 07-26-2024, 10:20 PM #6
Let us know.
You can't do a wheel alignment on a car with a solid rear axle, like the 4Runner.
Old 07-26-2024, 10:26 PM #7
What are the units on the dial gauge? If the run out is small, you can probably live with it. If the run out is large, I would think you would have a vibration when you drive.
Old 07-27-2024, 12:44 AM #8
Good question and I don’t know. It seems the new brake pads got rid of the squeeking when I brake. However, I do have some squeeking when the rear drivers side suspension is compressed but no vibration.
Old 07-27-2024, 07:56 AM #9
My bad. Not right what I posted.
Old 07-27-2024, 12:54 PM #10
No abnormal wear pattern on my rear tire.
Old 07-29-2024, 08:04 AM #11
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Then you are good to go, get your brakes done somewhere you trust other than dealer or find the time to do yourself.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 07-29-2024, 10:14 AM #12
El Dusty's Avatar
El Dusty's Avatar
I understand that but reading an alignment on the rear axle on a 4runner would still describe camber problems like a bent axel housing or bent axel flange. Like I said it wouldn't tell the whole story.
Old 07-29-2024, 12:13 PM #13
apc9199's Avatar
apc9199 apc9199 is offline
apc9199 will become famous soon enough
apc9199's Avatar
If that is a metric indicator, your total indicated runout is around .1mm or less than .005". I don't know what factory spec is but I wouldn't let them touch my vehicle over this issue. Get the brakes done and continue to happily drive your vehicle.
apc9199 is offline   Reply With QuoteReply With Quote
Old 07-29-2024, 04:15 PM #14
El Dusty's Avatar
El Dusty's Avatar
If it was measured at 0.1mm runout then this would be close to double the allowable per the manual. It is a ridiculously small tolerance.
With 0.05mm runout on a 6.5" flange it would be at a 0.017° angle. With 0.1mm of runout it would increase to .0347°.
How bad is the dealer gonna F me...?-capture-jpg
Old 07-29-2024, 04:38 PM #15
SocalSam SocalSam is offline
SocalSam will become famous soon enough SocalSam will become famous soon enough
You know your truck's driving and wear characteristics better than any service ticket writer or grease monkey who test drove around the block. Trust your instincts when dealing with these people.
SocalSam is offline   Reply With QuoteReply With Quote
axel , bent , pads , rear , vehicle
What’s your first mod gonna be? Big Country VA New Members 352 04-23-2024 06:04 PM
Lost Registration Package, Temp Tags to Expire. Dealer offered Dealer plate? Pieszeckipower Problems & Warranty Issues 2 09-18-2018 07:16 AM
Well, this is gonna be fun: johnsonnate 3rd gen T4Rs 15 04-05-2017 02:50 AM
I'm gonna do it! Thorgan112 3rd gen T4Rs 13 02-18-2015 04:35 PM
What's my next mod gonna be? fightman80 3rd gen T4Rs 37 11-04-2010 08:58 AM
