Old 07-31-2024, 02:53 PM #16
mbumpus11's Avatar
mbumpus11 mbumpus11 is offline
Real Name: Bump
mbumpus11 has a spectacular aura about mbumpus11 has a spectacular aura about mbumpus11 has a spectacular aura about
mbumpus11's Avatar
Real Name: Bump
I've had BFG KO2s on my 4Runner since the 2k mile mark on the ODO, and I now sit at 197k+. I'm only on my second set of BFG KO2s as well - the first getting about 93k miles, and these current tires are at end of life around 102k miles and right at 3/32" remain (getting new tires on Friday).
Going to be taking the plunge for some KO3s, I believe, and will run them in 275/70R17 range E as my last two sets of the KO2s have been.
KO2s have gotten pretty loud depending on road surface, and highways tend to make them sing like the crescendo of an opera. I hadn't noticed excessively loud road noise until about 15k ago, which an AT tire getting to ~90k miles before getting really loud is impressive to me.
I have occasionally found a little slip on urban roads after a fresh rain during a turn, but otherwise have continued to feel planted on the ground during rainstorms and other general driving despite running 40psi in all four tires.
My driving is probably 75-80% highway/city streets and the remainder being dirt/gravel/small river rocks/etc when on hunting land/construction sites/dirt-sand-gravel roads. I could probably use a less aggressive tire on the highway, but when I go out in the sticks it is typically rough and unpredictable. Have driven down to and through many a river and the KO2s have never failed to get me out of the silt and sand that accompanies those locations. I also have never had a puncture from cactus thorns/sticks/etc when driving around the ranch.
Excited to take a swing at the KO3s and see if they are truly an improvement like it appears they are.
2015 Magnetic Gray Trail Premium - Build Thread: https://www.toyota-4runner.org/5th-g...ight=mbumpus11 <<<--- click that to see what I've done
mbumpus11 is offline   Reply With QuoteReply With Quote
Old 07-31-2024, 03:41 PM #17
Originally Posted by Tec548 View Post
Tell me more about it.. who make this?
bfg makes them. for HD trucks.
BFGoodrich HD Terrain T/A KT | BFGoodrich
Old 07-31-2024, 09:14 PM #18
///AIRDAM's Avatar
///AIRDAM ///AIRDAM is offline
Real Name: Adam
///AIRDAM will become famous soon enough
///AIRDAM's Avatar
Real Name: Adam
I have been using BFG KM3 285/75/17 for years many, many 100k miles. I air down to 27psi off road and air up to 42psi for the highway drive.
Here is my question. After logging several 100k miles I am looking for a quieter tire for the highway... if that even exists.
Kinda weird, i run less pressure than your "aired down" ON THE HIGHWAY...
Have you considered the General Grabber X3, i have a friend with them and they are not nearly as loud as the KM3 and Toyo M/T.
I run General ATX all terrains and have for many hundreds of thousands of miles, i have owned BFG KM3 and TA and TA K/O, and i much prefer the General all terrain tire much better. After having such great luck with them a buddy decided to also try the General Grabber X3 MT on his very heavy work bed F250 and hes having great mileage and they seem quieter than most mud tires. I cant say about the coopers or falkens or any of those, i dont see them much around here.
I get very very high mileage out of my General tires, my current General Grabber ATX on my daily driver 4runner has DOUBLE the mileage on them as the most i ever got out of a set of BFG tires and my Generals still have life left in them.
This picture i took when they had 102,000 miles to send to all my buddies, these tires are going to go to 125,000.
Oh, i run 28psi up front and 24psi in the rear. Kinda weird you air up to 42psi to run the road, seems like the tire would be ballooned up and riding on the center of the tread. I run cross country a lot, pull trailers a lot, have been to the tip of Baja mexico and back and chased multiple desert races in Baja, been from San Diego to Miami to Mississippi pulling a trailer in less than a week. The mileage of these is unbeatable, they are uber quiet, handle exceptionally well, i would suspect their mud tires would be just as good and better than everything else on the market.
tire choice for long highway and extreme offroad-737053710-jpg  tire choice for long highway and extreme offroad-737053720-jpg
current
2005 Tundra DC limited + 2008 4R Urban Runner + 2023 4R TRD Sport
past
2008 Tacoma TRD Sport DC TRD supercharged + 2012 4Runner Limited
///AIRDAM is offline   Reply With QuoteReply With Quote
great , highway , m/t , miles , road
Tire choice for 2018 TRD Offroad The_Mickstar 5th gen T4Rs 46 11-22-2023 04:44 AM
What would the 4Runner’s highway ride be like with a long travel kit such as this? 2021nightshade4x4 5th gen T4Rs 1 02-14-2022 01:13 AM
What is the happy highway offroad medium 4RnnrHntr 4th Gen T4Rs 5 12-08-2014 03:55 PM
Tire choice kenlainpro_ 4th Gen T4Rs 29 04-24-2013 10:24 AM
Extreme offroad ironing Satman Off Topic 0 05-07-2007 02:44 PM
