Old 08-01-2024, 02:44 PM #1
8086bruce 8086bruce is offline
8086bruce is on a distinguished road
2024 Limited: Time for a lift!
I have a 24 Limited I purchased this spring. At purchase I did a 1" front cornfed spacer and a set of 275/55r20 toyo at3's. I would like to do an actual lift. 2.5/1.5ish.
So far I have 5 17x7.5 ORP wheels and an RCI skid plate and will be running 255/80R17 tires.
I have been reading threads on here for months and have myself confused on what to do for a lift. Some of the threads are a few years old so I'm not sure if there are newer players that have immerged as the go to.
Like I stated above I would like a 2.5-3 front and a 1.5-2 rear lift. I'm fairly set on running Camburg upc's but lift part I'm all over the board. I live in MN with salt so I want to stay with something that will be somewhat corrosive resistant and won't have the 4runner lean when I'd done. Budget is 3-4k for parts.
Looking for advice and what has worked well for members. Thanks in advance for the guidance!
2024 Limited Windchill Pearl/ 1" cornfed front spacer/ 275/55R20 Toyo AT3
8086bruce is offline   Reply With QuoteReply With Quote
Old 08-01-2024, 04:02 PM #2
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Due to the suspension geometry, a 1" spacer at the top of the strut on the front results in about 2.5 to 3.0" lift. You want more than that?
For the rear, though it is 1:1. A 1" spacer at the top of the rear spring results in 1" lift.
I have the Rough Country leveling kit: about 1" spacer on the front (3" lift) and 1" spacer on the rear. Front spacer is aluminum, so won't corrode, and rear spacer is hard rubber, again, no corrosion.
fkheath is offline   Reply With QuoteReply With Quote
Old 08-01-2024, 04:37 PM #3
The cornfed spacer is a 1/2' spacer resulting in about an inch of front lift.
I'm looking to ditch the factory Xreas system and replace it with lift springs and shocks as well as uca's.
Old 08-06-2024, 02:52 PM #4
I've been looking at the 6112 or Eibach stage 2R. Is there any other lifts I should consider? Thanks!
lift , limited , running , set , threads
My new 2024 TRD Off Road and what I think about it trainman605 General Discussions 4 03-31-2024 09:02 PM
2024 Limited… Is this a good deal please? Unstable Vic 5th gen T4Rs 7 02-12-2024 04:14 PM
Latest on 2024 4R? NMJack 5th gen T4Rs 35 06-25-2023 06:50 AM
Can you tell from the VIN if a Limited model is part-time or full-time 4WD? speedmaster General Discussions 6 10-07-2020 09:55 PM
Time to replace shocks/struts. Good time to lift? atalarico 3rd gen T4Rs 0 06-24-2011 09:50 PM
