Old 09-06-2024, 11:33 AM #1
BADCLOWN's Avatar
BADCLOWN BADCLOWN is offline
BADCLOWN is on a distinguished road
BADCLOWN's Avatar
HVAC question: rough start
I have a 2017 TRDP with 51k miles. Over the last few months I have noticed that after the truck sits for a few days I go to start it (starts fine) and regardless of whether I let the truck warm up or not, I turn on the fans (does it with just outside air and with the AC) it has a real clunky/rough start.
Any idea what this could be/anybody experience the same thing?
2017 Toyota 4Runner TRD Pro Cement Gray - OE blackout badges, Innovativ HIDs, OE LED fogs, AJT, black TRD shifter, 33inch light bar, K&N, CanvasBack, Toytec 2 inch lift, 34 inch tires, 2021 TRDP wheels, URD
BADCLOWN is offline   Reply With QuoteReply With Quote
Old 09-06-2024, 01:49 PM #2
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Any fan/blower noise issues I remember reading here involved the blower motor and / or attached squirrel cage. The motor can fail or make noise and the cage can get full of debris from critters or just outside dirt, leaves, etc. over time. You might be able to partially check things out by removing the cabin air filter in the back of the glove box. You'll have to remove the glove box to get a good look.
Old 09-06-2024, 02:46 PM #3
BADCLOWN's Avatar
BADCLOWN's Avatar
I can feel this in the front/motor area as well, I don’t know if that helps at all. After the initial start up, if I drive somewhere park and get out, when I come back and start the truck up then turn the HVAC on I don’t feel anything/feels fine
Old 09-16-2024, 04:15 PM #4
Mberrie Mberrie is offline
Mberrie is on a distinguished road
This is after the car is started? And when you turn on the HVAC fan it makes the noise? Only thing under the hood would be the AC compressor but if it does it without the AC being turned on that likely is not your culprit. Seems like a blower motor issue. Not hard to access at all. I have pictures of the glovebox removal process to gain access to that area.
Mberrie is offline   Reply With QuoteReply With Quote
Old 09-16-2024, 10:52 PM #5
BADCLOWN's Avatar
BADCLOWN's Avatar
This is after initial start up when it’s been sitting for a few days. And the HVAC is OFF when starting. Once it’s running and the HVAC is turned ON (AC or non-AC) I feel this weird clunking, it’s almost audible I feel like.
Old 09-17-2024, 10:46 AM #6
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Check the bearings in the compressor and any idler pulleys. A clunk is often a bad bearing. With the belt off, all pulleys and the compressor should run smoothly with no wobble.
fkheath is offline   Reply With QuoteReply With Quote
air , fans , start , truck , turn
1987 22RE Turbo Rough start and rough idle. mastermechanicjt Classic T4Rs 4 04-25-2017 08:40 PM
Rough start! need some help V2 dirt__diggler Classic T4Rs 4 02-23-2017 01:48 AM
Rough start when Hot quatin 3rd gen T4Rs 6 04-17-2016 09:47 PM
rough start/low idle on start Duhockey 3rd gen T4Rs 14 06-19-2010 04:28 AM
My new T4R and I having a really rough start... Rapter 3rd gen T4Rs 16 02-22-2010 07:57 PM
