Old 09-21-2024, 05:22 PM #1
PearlT4R PearlT4R is offline
Real Name: Pawel
PearlT4R is on a distinguished road
Real Name: Pawel
A/C issue intermittent
2017 4Runner here. The issue started over the winter intermittently. Heat worked fine for a bit, then took a vacation for a day or 2, then back to working again. I had no time to take it anywhere due work. Then, just as I was about to go in with summer approaching, voila. A/c works just fine, and it kept working all summer until now. Same start/stop issue. Does anyone have any ideas on what it can be before i take it in? I'm thinking it's the control assembly for the climate control. I appreciate any help guys. Thanks.
Current Ride:
2017 Blizzard Pearl Toyota 4Runner Limited
Gone but not forgotten : 2007 Phantom Black Pearl Audi RS4 6-speed | 2004.5 Platinum Gray Volkswagen Jetta GLI 6-speed | 2005 Milano Red Acura RSX Type-S 6-speed
PearlT4R is offline   Reply With QuoteReply With Quote
Old 09-21-2024, 06:29 PM #2
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb is a jewel in the rough ArthurKotb is a jewel in the rough ArthurKotb is a jewel in the rough
ArthurKotb's Avatar
Real Name: Rich
So it's both heat and cool not always working? Definitely sounds like cooler controls.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 09-22-2024, 04:25 PM #3
Okierunner69 Okierunner69 is offline
Okierunner69 is on a distinguished road
Does the AC light flash? Does is still blow air just not cold?
Okierunner69 is offline   Reply With QuoteReply With Quote
Old 09-23-2024, 02:36 PM #4
Real Name: Pawel
Real Name: Pawel
No flashing light. A/c and heat both work fine sometimes. It'll blow on full perfectly fine on one car ride. Then not work at all on a different car ride.
Current Ride:
Old 09-25-2024, 06:24 AM #5
jaredhouck jaredhouck is offline
jaredhouck is on a distinguished road
This sounds like a dying blower motor issue. I just had the exact symptoms in a Lexus. Use a multimeter to check for 12v at the blower motor. If you have 12v at the blower motor and the fan's not moving, replace the blower motor. Not hard to replace and not too expensive.
https://www.youtube.com/watch?v=d5qBWsZEYnw
jaredhouck is offline   Reply With QuoteReply With Quote
Old 09-25-2024, 07:47 AM #6
jdm-v35 jdm-v35 is offline
jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough
I had a similar issue with the AC intermittently working. My issue was that my belt chewed through a hose and when i replaced it I did not add enough refrigerant back in. It was just below the minimum threshold causing it to see low pressure when it got cooler out which triggered a safety in certain temps and the compressor would stop running(pressure was affected by temps). My heat still worked fine though. If you are having both heat and AC issues it most likely is the control panel or the temp sensor.
2018 TRD ORP w/ Magnuson
jdm-v35 is offline   Reply With QuoteReply With Quote
a/c , control , fine , issue , summer
Intermittent electrical issue llennium 4th Gen T4Rs 10 03-22-2023 02:08 PM
Intermittent Starting Issue Pale Rider 4th Gen T4Rs 18 03-01-2023 08:39 AM
Intermittent Headlight Issue. ewgee 4th Gen T4Rs 5 01-02-2023 01:41 AM
Intermittent AC issue renau001 5th gen T4Rs 4 12-20-2021 10:02 AM
'05 4R - Intermittent A/C Issue 4vrfit Problems & Warranty Issues 5 05-30-2014 01:21 PM
