Old 09-25-2024, 11:35 AM #1
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
'18 4Runner front brakes squeaking after brake job
Hi everyone, first let me start by saying I've done dozens of brake jobs and I've had a couple where they squeaked a bit afterwards, but never like this. Usually the resolution has been to lubricate the moving parts and a thorough cleaning of the caliper, but not in this case.
At about 48K my brakes were getting a little thin, so I replaced the front and rears (no rotors) with a quality set from autozone that others had recommended. No issues at all for the first couple weeks, then after the vehicle sits for a period it will make a terrible screeching sound when the brakes are initially applied. I've removed them at least twice now, checked the calipers, pins etc but the result is the same, they still screech. The good news is that it doesn't do it while I'm driving around. I really don't want to replace a brand new set of pads, but I'm not sure what else to do, other than live with it. Maybe the pads themselves are defective. Guess maybe I should have just gone with the factory ones instead.
Any suggestions are welcome.
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 09-25-2024, 12:32 PM #2
MAXISTYLES's Avatar
MAXISTYLES MAXISTYLES is offline
MAXISTYLES will become famous soon enough
MAXISTYLES's Avatar
Shim Kit will likely fix this. I had a similar issue with Toyota oem pads when installed without shims.
MAXISTYLES is offline   Reply With QuoteReply With Quote
Old 09-25-2024, 01:49 PM #3
JAXJeremy's Avatar
Real Name: Jeremy
JAXJeremy's Avatar
Real Name: Jeremy
Interesting. I seem to recall the factory pads had a metal back that pulled away when I removed them. The current pads I have, have the same thing.
Old 09-25-2024, 02:12 PM #4
JAXJeremy's Avatar
Real Name: Jeremy
JAXJeremy's Avatar
Real Name: Jeremy
Found these, maybe I'll give them a try.
Just a moment...
Old 09-25-2024, 02:37 PM #5
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
From your description it sounds like this only happens after sitting for awhile. Could it just be a little surface rust build up on the rotors?
Did you do proper bed in? Since you switched to different pads they are a different friction material and that material needs a nice layer transferred over to the rotors that still have the previous friction material.
Another thought, more aggressive friction material will squeal when cold. Essentially its ideal operating range is a higher temp and they don’t like being cold. My Mustang was like this.
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 09-25-2024, 03:22 PM #6
JAXJeremy's Avatar
Real Name: Jeremy
JAXJeremy's Avatar
Real Name: Jeremy
Thanks. We're not talking about it even sitting over night, it can sit for a few hours and still do it.
Followed the bed in procedures and like I said they didn't do it for a few weeks.
Good call on the friction material. I bought a premium brand of pad but they weren't a high performance style by any means.
Old 09-26-2024, 12:56 AM #7
bzizzi's Avatar
bzizzi bzizzi is offline
bzizzi will become famous soon enough
bzizzi's Avatar
Just put some grease on them that will fix the squeeking.
bzizzi is offline   Reply With QuoteReply With Quote
Old 09-26-2024, 08:20 AM #8
JAXJeremy's Avatar
Real Name: Jeremy
JAXJeremy's Avatar
Real Name: Jeremy
Tried that, twice and I even spent the $ on the good permatex stuff.
Permatex 24125 Ceramic Extreme Brake Parts Lubricant
Old 09-26-2024, 11:21 AM #9
Rocko9999 Rocko9999 is offline
Rocko9999 will become famous soon enough
Should use OEM Pads with OEM shim kit. You might get OEM shims to fit on those pads you have.
Rocko9999 is offline   Reply With QuoteReply With Quote
Old 09-26-2024, 01:12 PM #10
JAXJeremy's Avatar
Real Name: Jeremy
JAXJeremy's Avatar
Real Name: Jeremy
That's what I'm hoping
Old 09-26-2024, 07:54 PM #11
Soulprogression108's Avatar
Soulprogression108 Soulprogression108 is offline
Soulprogression108 is on a distinguished road
Curious if the pads were semi metallic? Just been watching video on Vikings Garage on youtube for a brake bleeding video and he mentioned how pads with any metal ie semi metallic in the pad material will cause this. Anyway probably not but saw your post and thought to mention it.
Current: 2011 Trail Edition T4R
Bilstein Leveling Kit: 6112's and 5160's
TRD 17" Gold Wheels 31" TA's
Sold:1994 T4R 22re 4x4 MT
Aluminum Weld 15's and 31x10.5 BFG ATs
Soulprogression108 is offline   Reply With QuoteReply With Quote
brakes , couple , front , pads , set
Squeaking Brakes? FlannelShanel Maintenance/Detailing 2 03-09-2018 10:26 AM
Brakes squeaking...HELP!? RHINO-99 Maintenance/Detailing 4 01-31-2009 11:55 AM
Brakes squeaking Barkley Problems & Warranty Issues 4 05-11-2008 05:55 AM
My brakes are squeaking AGAIN Falls 4th Gen T4Rs 19 01-01-2008 01:42 AM
My brakes are squeaking Falls 4th Gen T4Rs 14 11-13-2006 11:05 AM
