Old 10-14-2024, 05:23 PM #1
lj4r lj4r is offline
lj4r is on a distinguished road
Codes C1404, C1445 and C1452
We have a 2016 4Runner SR5 Premium 4x4. I had some dash lights come on last week as I was driving along. I did a scan and the following codes showed:
1. C1404
2. C1445
3. C1452
The Dash lights that came on were as follows:
1. ABS
2. Brake (red)
3. Skid Control
4. 4LO (flashing)
5. Center Lock (flashing)
I tried disconnecting the battery and reconnecting, nothing changed.
C1404 looks like the Rear Left Side Speed Sensor
C1445 is "vehicle driven with Steering Angel Sensor Not Initiated
C1452 is Accumulator Low Pressure
The 4Runner doesn't have the simple speed sensor as a separate part, you need to get the sensor and wire harness, about $205 from Larry H. Miller Parts online with discount.
Any thoughts? Does it appear to be just the speed sensor? Rear brakes were done about two months ago by a local shop (daughter had the 4runner at college). Changed out rear rotors and pads.
Thanks Phil
lj4r is offline   Reply With QuoteReply With Quote
Old 10-16-2024, 01:51 PM #2
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Some folks with similar symptoms on past threads found broken or damaged ABS wires from brake work, off-roading, accidents or other issues. I would check those.
Old 10-18-2024, 01:57 PM #3
I did a visual on the wiring, it all looked good. I may just change out the sensor/wiring and see if that fixes the issue.
Old 11-01-2024, 05:09 PM #4
So I pulled the ABS sensor on the left rear axle. There were metal shavings on it and the sensor was damaged. Grinding noise from the axle. Sounds like the axle bearing may be shot. Is it easier to just swap out a replacement axle or to replace the bearings and seal? Thanks
c1404 , c1445 , c1452 , sensor , speed
2011 4Runner Limited Error Code DTC C1452 Help Saltfevertx 5th gen T4Rs 5 01-08-2022 06:18 PM
C1223/C1256 abs codes on scanner but no engine codes or lights keakar 4th Gen T4Rs 4 04-22-2019 02:37 PM
ABS/Traction light C1405 and C1445 bcool 5th gen T4Rs 5 10-24-2017 03:02 AM
We heard you like OBD codes so we added codes to your codes thinkCooper 3rd gen T4Rs 47 01-29-2017 12:54 PM
