Old 10-23-2024, 01:06 PM #1
ToyDB ToyDB is offline
ToyDB is on a distinguished road
5th Gen Limited - Replace XREAS with Bilstein 4600 or 5100
Hello,
Need to replace my leaking XREAS shocks/struts on my 2018 Limited. Likely to remove XREAS and get Bilstein 4600s or 5100s. Will keep stock springs, wheels and tires. Primarily city/highway driver with occasional light trail/towing.
Can anyone share their experience with replacing the XREAS units with either of the Bilsteins in terms of ride and handling?
Thanks!
ToyDB is offline   Reply With QuoteReply With Quote
Old 10-23-2024, 01:49 PM #2
Humble Leader's Avatar
Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold
4600 or 5100 will be fine. the ride will be similar to XREAS with those two options. the 4600s will be fine for stock height if you want to save some $. the 5100s can be used in a lift. neither one is really 'better' than the other, although the 5100s can be used at stock height as well
since you are using factory springs, you probably won't need to be as concerned about driver side lean as I believe the passenger and driver spring are different heights. if you get new springs then a 5100 might be a better choice so you can set the passenger side at different height to balance the truck and use the same spring for both driver and passenger side
how long did your XREAS last? 2018 is pretty recent for a failure. if you have caught the leak early or it's a very minor weep / leak you can replace individual components of XREAS if done properly and not too much fluid has been lost
Old 10-23-2024, 03:20 PM #3
Thanks. Struts started leaking at around 95K miles. Not going to lift so I'm leaning towards 4600s and the more compliant on-road ride. On the other hand, the slightly firmer 5100s will give a handling/stability edge over the 4600s. I'm hopeful either will offset any stability/handling loss from removing the XREAS. Always a tradeoff somewhere.
Old 03-06-2025, 12:22 PM #4
Scuba6's Avatar
Scuba6 Scuba6 is offline
Scuba6 is on a distinguished road
Scuba6's Avatar
Follow up Question
Did you end up going with the 4600s, and if so, any thoughts 5 months on?
I need to change out my 2011 Limited's XREAS and reading up on the options. My use case is almost exclusively on-road use, but I am now towing a 2800lb travel trailer about once a month for trips.
Does the need to tow change the recommendation for the 4600s?
Thanks!
2011 Mag Grey Limited Probably not as modded out as yours
War Eagle!
Scuba6 is offline   Reply With QuoteReply With Quote
Old 03-07-2025, 10:56 AM #5
Thanks!
the 4600s will be fine to tow, you can get stiffer springs in the back to help with squat though
bilstein , light , limited , replace , xreas
4600 vs. 5100 - Here's What Bilstein Says Bluesky 07 4th Gen T4Rs 13 07-19-2021 04:30 PM
2006 V8 Sport XREAS to Bilstein 4600 Conversion jmriott 4th Gen T4Rs 2 08-29-2020 11:08 PM
Superflex With Bilstein 4600 and 5100 Tyler James Inc 3rd gen T4Rs 12 03-02-2017 01:37 AM
Bilstein 4600 vs 5100 vs washboard roads Andy42 4th Gen T4Rs 8 05-19-2016 11:59 PM
Bilstein 5100 or 4600 with OME 906? Robb235 3rd gen T4Rs 11 03-08-2015 08:44 PM
