Old 11-09-2024, 08:24 PM #16
hoobhoob's Avatar
hoobhoob hoobhoob is offline
hoobhoob is on a distinguished road
hoobhoob's Avatar
Recently replaced mine at 100K km. Super easy to due with just a 14mm socket. I used the 7PK2145 version and no issues (1000 km so far.)
Old one looked in good shape as expected and is now tossed in the jack hole as a spare. I already have a box of tools/recovery gear in the back anyway so this can be a roadside/trail repair if needed.
hoobhoob is offline   Reply With QuoteReply With Quote
Old 11-12-2024, 10:14 PM #17
AMLOR AMLOR is offline
Real Name: Kirk
AMLOR has a spectacular aura about AMLOR has a spectacular aura about
Real Name: Kirk
Pulleys too...
If you are going to change out the serpentine belt REGARDLESS of the exact miles; PLEASE check your idler pulleys for lateral (side to side) run-out.
I did this on my 2019 with about 95K on it and 2 of the 3 idlers were significantly worn. Both if these were the UPPER idler pulleys.
NOTE: on mine, neither upper idler had any dust shields on either side.
The lower idler was perfectly fine, no side to side at all. Tensioner pulley was equally fine.
Good Luck
AMLOR
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb rear springs, DrawTight Class IV frame hitch, Method Racing 703 Bead Grips, goodies from URD.
AMLOR is offline   Reply With QuoteReply With Quote
Old 11-21-2024, 11:44 PM #18
MannMade82 MannMade82 is offline
Real Name: Jason
MannMade82 is on a distinguished road
Real Name: Jason
Just take your time and it isn't difficult to do. I used the Bando belt with the same part number printed on it as the OEM one. I also have this tool set, link below, and made it sooooo easy to replace:
Amazon.com
2015 SR5 Premium 4x4 Super White
TRD CAI - n-fab Nerf Steps - Philips X-treme LED fogs - XenonDepot Philips HID Low Beam - Interior & Exterior LEDs - Bilstein 5100 All Around: Front 1.75", Rear 1" Cornfed spacers - Prothane/Whiteline front & rear sway bar bushings - General Grabber ATX 265/70/17 - ARB On Board Air
MannMade82 is offline   Reply With QuoteReply With Quote
Old 11-22-2024, 02:55 PM #19
Rocko9999 Rocko9999 is offline
Rocko9999 will become famous soon enough
Amazon.com
The link doesn't work for the tools.
Rocko9999 is offline   Reply With QuoteReply With Quote
Old 12-04-2024, 04:09 PM #20
BTO's Avatar
BTO BTO is offline
BTO is on a distinguished road
BTO BTO is offline
BTO's Avatar
Originally Posted by Too Stroked View Post
Just because Bando is the OE supplier to Toyota does not mean that the belts they sell under their own brand name are the same as the ones they supply to Toyota. Same goes for Denso (and other) OE and aftermarket parts.
How do I know this? I might just work in a Toyota Parts department.
But why would they sell a lesser belt under their own name? That does not make sense to me.
BTW, I just bought a Bando 7PK2150 on amazon because I can see the "7PK2150" printed on the original belt. I'll compare it to the original belt very closely before I install it. I don't want to take any chances with this.
BTO is offline   Reply With QuoteReply With Quote
Old 12-06-2024, 08:28 PM #21
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
It's actually a very long story - that I won't get into here. In short, parts made for Toyota by Toyota OE suppliers are made to Toyota specifications and sometimes using tooling owned by Toyota. That said, tooling owned by Toyota cannot be used for anything - or anybody - else.
On the plus side, buying parts from a Toyota OE supplier is generally better than buying from somebody who is not. That's because the Toyota OE suppliers know what's important to Toyota and can use that knowledge in building parts that they sell under their own branding. For instance, I have it on very good advice that the Denso alternators that you can buy on RockAuto and other places are not as good as the ones that are supplied to Toyota. Hmmm.
As for buying parts on Amazon or eBay that claim to be "OEM Toyota" this is still a somewhat risky bet. The number of counterfeit parts with convincing looking markings on them is getting to be a real problem. Just Google "counterfeit NGK spark plugs" to see what I mean.
Hope that helps.
Too Stroked is offline   Reply With QuoteReply With Quote
Old 12-10-2024, 10:19 AM #22
mofokid69 mofokid69 is offline
mofokid69 is on a distinguished road
How was the comparison, did the belt from amazon was to quality?
mofokid69 is offline   Reply With QuoteReply With Quote
Old 12-11-2024, 03:17 PM #23
BTO's Avatar
BTO BTO is offline
BTO BTO is offline
BTO's Avatar
The belt did arrive and looks good but I have not yet installed it or compared it side by side. I can report the new belt has "BANDO RIB ACE" printed on it and so far looks the same as the stock belt. Once I get it installed I will update this thread.
Old 12-11-2024, 10:31 PM #24
I got these from amazon, idlier pulleys and tensioner as well for $100 cad, everything looks good so far.
Should I replace the drive belt on my 2016 with 70k miles?-pxl_20241212_010708653-mp~2-jpg  Should I replace the drive belt on my 2016 with 70k miles?-pxl_20241212_010655450~2-jpg  Should I replace the drive belt on my 2016 with 70k miles?-pxl_20241212_010649771~2-jpg
Old 12-16-2024, 12:13 AM #25
Real Name: Jason
Real Name: Jason
Search on Amazon for:
GEARWRENCH 15 Piece Ratcheting Serpentine Belt Tool Set | 3680D
Old 12-28-2024, 04:43 PM #26
BTO's Avatar
BTO BTO is offline
BTO BTO is offline
BTO's Avatar
I finally got around to attempting the serpentine belt replacement with the Bando 2150. It did not go so well. I have confirmed the Bando 2150 is the exact same size as the stock belt, but the rib design is different.
The belt on the left is the stock belt which is a Toyota part number 99367-H2150 made by Mitsuboshi (part # 7PK2150) made in Indonesia.
The Bando on the right.
The bottom pic shows the different rib design. The stock belt on the left.
Should I replace the drive belt on my 2016 with 70k miles?-img_2720-jpg  Should I replace the drive belt on my 2016 with 70k miles?-img_2719-jpg  Should I replace the drive belt on my 2016 with 70k miles?-img_2718-jpg
Old 12-28-2024, 07:42 PM #27
djeepin djeepin is offline
djeepin will become famous soon enough
leave original belt alone. it will not disintegrate at once. after Toyota numbering wears out, may be threads become visible, then start thinking replacing it. some rollers, idle one, may look loose, but its not. many falls for that trick dealership scaring tactic. unless it is really noisy and bearing fails
Leave that belt alone.
djeepin is offline   Reply With QuoteReply With Quote
Old 12-28-2024, 07:42 PM #28
BTO's Avatar
BTO BTO is offline
BTO BTO is offline
BTO's Avatar
Turns out this information was already posted but I didn't see it. https://www.toyota-4runner.org/3514162-post42.html
I went ahead and installed the Bando 7PK2150. I'll keep the old stock belt and monitor the Bando. Crossing my fingers!
The guy on YouTube I followed https://www.youtube.com/watch?v=T4hcXCKsfnA stated his stock belt was a Bando. His 4Runner I think is newer than ours which is a 2018 TRDORP.
Does this mean the Mistubushi belts came on the older 5th gens? And at some point the supplier was changed to Bando? Would that change coincide with the change in Toyota part number? 99367-H2150 was superseded by 90916-A2015.
Old 12-28-2024, 07:46 PM #29
BTO's Avatar
BTO BTO is offline
BTO BTO is offline
BTO's Avatar
Damn. Already changed it. We have put 7 years and 100K miles on the stock belt. I was doing a complete 100k maintenance. I have always changed the serpentines every 100k on previously vehicles. But your right, I probably could have gone another 50k on it.
Old 12-29-2024, 12:31 AM #30
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
I’ve got 6 years and 54,000 miles on my $12 Amazon Bando replacement with no issues. I bought the 2150mm because that’s what came off.
2010 Trail - 146k mi - KDSS - Classic Silver Metallic - Bilstein 5100s - Tires: Michelin X-LT A/S 36psi - Oil: M1 EP 5W/30 - Diffs and T/C: Delvac 75W-90 Synthetic - Toyota WS ATF - ScanGauge - Viofo dashcam - Husky Weatherbeaters - Plasti Dip wheels and chrome delete - Wheel Center Caps delete - Roof Rack Cross Bars delete - Cargo Tray divider delete
1000MPH is offline   Reply With QuoteReply With Quote
70k , belt , drive , miles , replace
Can I drive without AC belt? Aelfwine 3rd gen T4Rs 20 09-26-2020 10:48 PM
Timing Belt Tensioner: Should I replace it when doing the timing belt change? Lugnutz 3rd gen T4Rs 14 05-12-2011 12:58 PM
Drive Belt DIY superdjl 4th Gen T4Rs 1 01-08-2011 09:46 PM
How much for a new drive belt? dannyg 4th Gen T4Rs 9 09-29-2010 07:06 PM
