Old 11-08-2024, 01:58 PM #1
Muzzle of Bees Muzzle of Bees is offline
Muzzle of Bees will become famous soon enough
Throttle Body
I noticed a few months back that during acceleration the gas pedal felt a little sticky. Yesterday afternoon I spent about an hour researching and cleaning the throttle body and that really makes the acceleration much smoother. I didn’t have any throttle body cleaner but I did have some starter fluid in an aerosol can that worked just fine. I wiped out a bunch of carbon from inside of the throttle body. There are good videos out online but one thing that was missing from the videos and helped me get the hose back on easily was to loosen the top of the air cleaner so you get more room to get the hose on the bottom nice and solid.
2016 TEP
Muzzle of Bees is offline   Reply With QuoteReply With Quote
Old 11-09-2024, 12:37 AM #2
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
You know it’s drive-by-wire right?
2010 Trail - 146k mi - KDSS - Classic Silver Metallic - Bilstein 5100s - Tires: Michelin X-LT A/S 36psi - Oil: M1 EP 5W/30 - Diffs and T/C: Delvac 75W-90 Synthetic - Toyota WS ATF - ScanGauge - Viofo dashcam - Husky Weatherbeaters - Plasti Dip wheels and chrome delete - Wheel Center Caps delete - Roof Rack Cross Bars delete - Cargo Tray divider delete
1000MPH is offline   Reply With QuoteReply With Quote
Old 11-09-2024, 08:29 PM #3
hoobhoob's Avatar
hoobhoob hoobhoob is offline
hoobhoob is on a distinguished road
hoobhoob's Avatar
The electrons must be sticky too.
hoobhoob is offline   Reply With QuoteReply With Quote
Old 11-12-2024, 06:13 PM #4
Sure, but that doesn’t mean software can’t provide feedback when it knows something isn’t working correctly. I would bet that it has certainly advanced beyond its simplest capabilities.
I scrutinized the footwell and found nothing different from normal. I didn’t scrutinize the throttle body parts. I just cleaned it out.
By the way, conjecture is quite common with Americans.
2016 TEP
Old 11-12-2024, 09:54 PM #5
AMLOR AMLOR is offline
Real Name: Kirk
AMLOR has a spectacular aura about AMLOR has a spectacular aura about
Real Name: Kirk
throttle body shmutz....
You DID change out your PVC Valve once you cleaned out the TB...Right??
the biggest cause of crap in the TB is a (partially) clogged PCV Valve.
$5.99 and 15 minutes can solve the shmutz problem...
Good Luck
AMLOR
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb rear springs, DrawTight Class IV frame hitch, Method Racing 703 Bead Grips, goodies from URD.
AMLOR is offline   Reply With QuoteReply With Quote
Old 11-12-2024, 11:30 PM #6
1000MPH's Avatar
1000MPH's Avatar
Feedback through the gas pedal on the 4Runner? No.
back , body , cleaner , throttle , videos
2002 6cyl. 175k Vacuum leak, Throttle Body throttle lever? Hollywood1 3rd gen T4Rs 3 12-29-2018 06:25 PM
The small black plastic "cap" on throttle body near throttle cable - What is it? bugman-74 3rd gen T4Rs 3 03-10-2015 10:23 PM
Electric throttle body to cable throttle body conversion Dirtyfingers 3rd gen T4Rs 8 12-29-2014 10:05 AM
Throttle body troubles...WOT=half throttle Idahosr5 3rd gen T4Rs 0 10-31-2010 04:09 PM
