Old 11-14-2024, 11:13 AM #1
NYRunner NYRunner is offline
NYRunner will become famous soon enough
Mechanic I trust says I need to replace a frozen rear brake caliper, pad, rotor
My right rear brake started grinding really badly last weekend. Even at 1 mph until fully stopped. Brought it to a local mechanic I do trust, he said I should replace everything, and I just wanted to bounce this off the hive
He said the left one is sticky as well and that I should replace both sides, quoting my $900 and change for the whole job, including parts and labor. Said if I just sid the right side I’d only save $200 or so… and that I’d have to do the left side soon anyway
Truck has 146,000 and had my rear brakes seized up and repaired 5 years ago or so. My priority is safety and making sure everything is in proper working order as I’ll be keeping the truck for at least a few more years, is not for many many more…
Does this sound legit and is that price reasonable? I have no doubt a dealer would charge me twice as much for a similar job
Thanks in advance!
2010 Mag Grey Limited 4X4
NYRunner is offline   Reply With QuoteReply With Quote
Old 11-14-2024, 05:07 PM #2
osugsxr osugsxr is offline
Thanks in advance!
seems reasonable , call for quotes but if you trust that one id stick with it. I recently replaced front pads/rotor on my audi and was quote $1500-2200 and rear pads alone $700-900 DIY for about $250 in parts.
I havent replaced a caliber yet but pads and rotors are simple. Caliber might little extra work with bleeding of the brakes
Old 11-14-2024, 07:52 PM #3
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Probably OK, but I'd make sure he's using OEM parts. Even if it's a little more.
thennen is offline   Reply With QuoteReply With Quote
Old 11-14-2024, 09:01 PM #4
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
As has already been stated, the quality of the parts you use will have a dramatic effect on both the price and the longevity of the repair. Said another way, if you use cheap aftermarket parts, your repair bill will be low - as will how long the repairs last.
Too Stroked is offline   Reply With QuoteReply With Quote
Old 11-14-2024, 09:42 PM #5
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Had a full brake job done on my Tundra about a year ago and it was $900.
Old 11-15-2024, 09:03 AM #6
plummerg's Avatar
plummerg plummerg is offline
plummerg is on a distinguished road
plummerg's Avatar
I replaced both of my rears on my 2015 at 120k with my local trusted guy and it ran about that much. Made a huge difference in braking performance. Didn’t realize how bad it had gradually reduced over time. It’s like new again.
plummerg is offline   Reply With QuoteReply With Quote
Old 11-15-2024, 09:30 AM #7
not bad calipers , rotors and pads at $900 is a solid price
Old 11-21-2024, 11:56 PM #8
MannMade82 MannMade82 is offline
Real Name: Jason
MannMade82 is on a distinguished road
Real Name: Jason
Not horrible if you aren't going to do-it-yourself. OEM Calipers are about $171 each online. $77 each for OEM rotors. $50 for quality pads (Akebono) and another $10 for a hardware kit. Then you'd have a labor...not sure how many hours their system shows. I'd consider a brake fluid flush/change too if you haven't done it for awhile.
2015 SR5 Premium 4x4 Super White
TRD CAI - n-fab Nerf Steps - Philips X-treme LED fogs - XenonDepot Philips HID Low Beam - Interior & Exterior LEDs - Bilstein 5100 All Around: Front 1.75", Rear 1" Cornfed spacers - Prothane/Whiteline front & rear sway bar bushings - General Grabber ATX 265/70/17 - ARB On Board Air
MannMade82 is offline   Reply With QuoteReply With Quote
Old 11-22-2024, 01:44 PM #9
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
Sadly the calipers are known to freeze up, it's a known issue. If you trust the person I don't see an issue
i’d , job , rear , replace , truck
brake rotor/caliper/pad replacement - caliper piston, too? amheck 4th Gen T4Rs 16 11-08-2017 09:29 AM
Frozen Brake Caliper Pistons? zerowkul98 5th gen T4Rs 0 10-24-2017 09:40 AM
Need Seattle Mechanic for frozen Caliper Texas_4Runner 4th Gen T4Rs 4 07-03-2017 02:40 PM
rear brake caliper frozen? brettmc 4th Gen T4Rs 15 02-25-2016 12:35 AM
Frozen Brake Caliper eleven6988 4th Gen T4Rs 9 04-09-2012 08:20 PM
