Old 01-30-2025, 02:18 PM #16
thatoneguy's Avatar
thatoneguy thatoneguy is offline
thatoneguy is a jewel in the rough thatoneguy is a jewel in the rough thatoneguy is a jewel in the rough thatoneguy is a jewel in the rough
thatoneguy's Avatar
Originally Posted by 02SE View Post
The Single VVTi 1GRFE used from 2003-2009, and to 2015 in the Tacoma, is significantly different than the Dual VVTi 1GRFE used in 2010-2024 5th gen 4Runners, and 2010 and up FJ Cruisers.
Different block, crankshaft, cylinder heads, and intake and exhaust, etc, etc. It's so different, that I think Toyota should have changed the model designation of the engine more significantly than they did.
Yes, I've always been aware of that, but to me it's still the same general engine in the same engine family at the same displacement. If someone truly knows the exact nitty-gritty of how significant the changes are, exact measurements and all, I'd be interested. Such as how significant the block changes actually were.
In reliability discussions, generally nobody separates the single VVTI and dual VVTI 4.0L's as to be considered independently; we're all pretty comfortable putting them all under the 4.0L umbrella.
2023 TRD Offroad Premium, want to buy 2010+ TRD PRO exhaust, SLC area.
Former: 1987 SR5 w/ SAS, 1999 Limited w/ e-locker
thatoneguy is offline   Reply With QuoteReply With Quote
Old 01-30-2025, 03:59 PM #17
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
At one time I researched the differences. IIRC they shared some common bearing shells.
The Dual VVTi block had improvements for cooling, the liner cross-hatching was improved, and they were more securely attached to the block casting.
So while the Single VVTi 1GRFE, and Dual VVTi 1GRFE, are both 4.0 liter V6 Toyota engines, they share almost nothing in actual parts.
I find that most people, especially if they aren't Toyota enthusiasts, are unaware of that.
02SE is offline   Reply With QuoteReply With Quote
Old 01-30-2025, 06:17 PM #18
Soulprogression108's Avatar
Soulprogression108 Soulprogression108 is offline
Soulprogression108 is on a distinguished road
Well looks like some good news from Blackstone anyway. All readings are below average. That with the inspection I did with endoscope is really pointing me towards over all OK inside TC at least. I'll be doing another oil change soon to see what shows up and will check with magnet and see what's on the drain plug.
I'm pretty certain I've got the annoying whining idler gear issue and that my accy belt pulley's are starting to go bad. Double checking that and will replace if they need it. The TC idler gear is just a bummer but seems like many have this and have 150-300k miles on the engine. Shame to do the work to crack the front cover to replace a $20 part and possibly have the issue return in 40k.
Feeling a little better. Gotta say seeing the metal flake in oil and hearing some interesting sounds really had me stressing for a bit. I'm hoping all is well. Truck has really good maintenance records and low miles so would be sad to think there's a major issue.
Cause for concern in 1GR-FE-image-1-30-25-12-06-pm-jpg
Current: 2011 Trail Edition T4R
Bilstein Leveling Kit: 6112's and 5160's
TRD 17" Gold Wheels 31" TA's
Sold:1994 T4R 22re 4x4 MT
Aluminum Weld 15's and 31x10.5 BFG ATs
Soulprogression108 is offline   Reply With QuoteReply With Quote
Old 02-03-2025, 09:33 PM #19
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
It’s easy to release tension on the serpentine, spin the idlers and pull if necessary. I got a set when Toyota had a 25% parts sale. This year I splurged for a full tensioner that I hope I never need.
This is the pdf for changes on the 1GR-FE:
2010 Trail - 146k mi - KDSS - Classic Silver Metallic - Bilstein 5100s - Tires: Michelin X-LT A/S 36psi - Oil: M1 EP 5W/30 - Diffs and T/C: Delvac 75W-90 Synthetic - Toyota WS ATF - ScanGauge - Viofo dashcam - Husky Weatherbeaters - Plasti Dip wheels and chrome delete - Wheel Center Caps delete - Roof Rack Cross Bars delete - Cargo Tray divider delete
1000MPH is offline   Reply With QuoteReply With Quote
Old 02-10-2025, 05:32 PM #20
15Limited 15Limited is offline
15Limited is on a distinguished road
Originally Posted by flyrv9 View Post
The 1GR-FE engine is noisy; unless yours is making more noise than normal. Some folks here send an oil sample to Blackstone Labs for analysis. Some have posted their reports and they look pretty detailed. You could also install an analog oil pressure gauge so you could monitor oil pressure more accurately to better see if the oil pump is suspect; if there is a fitting on the engine for one.
Early in ownership, especially when driving on hilly roads, I couldn't help but notice how bad this engine sounds from inside. It made me seriously consider different headers but I didn't want to deal with warranty challenges. You get used to it, but never happy about it IMO.
2015 Limited
KYB Coilovers & G-Shocks
Michelin Defender LTX MS2
15Limited is offline   Reply With QuoteReply With Quote
chain , oil , pump , time , timing
How big of concern do you think this is? MrGainzz General Discussions 7 01-09-2018 04:05 PM
Cause for concern?? jonesmw10 4th Gen T4Rs 11 02-21-2015 01:15 PM
LBJ - Cause for Concern? Robb235 3rd gen T4Rs 14 10-10-2013 02:37 PM
Is this a cause for concern? Ilovesnow 4th Gen T4Rs 4 01-28-2010 03:00 PM
A/C Fan concern MikesToy Problems & Warranty Issues 1 09-15-2008 08:01 AM
