Old 11-26-2024, 02:52 PM #1
Soulprogression108's Avatar
Soulprogression108 Soulprogression108 is offline
Soulprogression108 is on a distinguished road
Cause for concern in 1GR-FE
Ok so quick back story. Truck is a 2011 and had full Toyota service record. I bought it with 70k on it and I have done two on time oil changes as well as change every other fluid.
Since I got it the truck has had a whine around 2k rpm more noticeable in lower gears and under load. I did a bunch of research. Apparently it's quite normal for this motor. Maybe not "right" but many claim this.
Now I tried to put it out of my head but it still bothered me a bit. I haven't had time to trace but it does seem louder by driver side. I've read possibly one of the pulleys for the Timing chain system.
Fast forward to yesterday. I do an oil change. Always use Toyota OEM filter and oil.
Oil was black at 5k miles. Concern was there were some metal flakes about size of an ant or a medium grain of sand (3 or so noticeable) and a very small amount of smaller specs. With my old truck at 300k 22RE it was kinda par for the course it was worn out time for a rebuild.
With this now I'm thinking that doesn't seem good. A little more research has pointed that some of these 1GR-FE's have had oil pump failure. This could contribute to the noise I'm hearing, but it could also be causing the Timing Chain System to not get properly lubricated (as well as upper parts of the motor)
I'm checking sound locations today with stethoscope, but want to get some input from anyone that might have experience here. Anyway to check without pulling Timing Cover? If I can determine indeed that the issue is oil pump then I may have to bite the bullet replace oil pump and all the timing guides, chain, idlers, etc. Really don't want to crack this engine with so little miles on it though.
Current: 2011 Trail Edition T4R
Bilstein Leveling Kit: 6112's and 5160's
TRD 17" Gold Wheels 31" TA's
Sold:1994 T4R 22re 4x4 MT
Aluminum Weld 15's and 31x10.5 BFG ATs
Soulprogression108 is offline   Reply With QuoteReply With Quote
Old 11-26-2024, 06:30 PM #2
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
The 1GR-FE engine is noisy; unless yours is making more noise than normal. Some folks here send an oil sample to Blackstone Labs for analysis. Some have posted their reports and they look pretty detailed. You could also install an analog oil pressure gauge so you could monitor oil pressure more accurately to better see if the oil pump is suspect; if there is a fitting on the engine for one.
Old 11-27-2024, 01:09 PM #3
ecally ecally is offline
ecally is on a distinguished road
I’ll be watching this thread. I have a 2023 but that exact noise you describe grates on me, wish I knew exactly what it is.
ecally is offline   Reply With QuoteReply With Quote
Old 11-27-2024, 04:50 PM #4
Humble Leader's Avatar
Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold
hard to diagnose without a video or assess how bad it is. the 5th gen 4runner engine kind of sounds broken all the time. metal shavings in the oil that are clearly visible though is likely a problem ...
Old 12-08-2024, 04:17 AM #5
Ya I need to get a good recording. I keep trying but get important calls, or have some other thing come up and the recording sounds bad. I'll try to get one this week. I also picked up a mechanics stethoscope so will poke around with it and see what I can find.
Old 12-08-2024, 04:18 AM #6
I did get a kit from blackstone labs and will send some of the oil from the last oil change soon. Intrigued to see what they say.
Just want to add that other than this noise the truck runs like a top. Idle smooth and plenty of power.
Old 12-08-2024, 01:00 PM #7
Yamahamer Yamahamer is offline
Yamahamer will become famous soon enough
Plenty of power? That's pretty subjective. I'd describe it as "adequate" power. Every time I drive my 2016 F150 with the 3.5 Ecoboost (over 200 more lb-ft of torque than the Toyota engine) I realize just how down in power that 4Runner engine is.
Yamahamer is offline   Reply With QuoteReply With Quote
Old 12-08-2024, 08:37 PM #8
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is just really nice Bmnorm2 is just really nice Bmnorm2 is just really nice Bmnorm2 is just really nice
You’ll want to catch the oil midstream , like a pee test. Oil analysis is probably the easiest way to start narrowing down where the metal is coming from.
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 01-02-2025, 02:03 PM #9
Meaning engine doesn’t feel down on power… I get your point. But to me coming from a 94 22re this thing feels like a beast hahaha. Personally I’m content with the power to weight of this vehicle. If I started adding bumpers winch huge tires I’d probably feel different.
Old 01-02-2025, 02:07 PM #10
Whippersnapper02's Avatar
You can always send an oil sample to crackstone crabs for testing but really this engine has been noisy when it was first used in 05.
Old 01-02-2025, 02:37 PM #11
BTO's Avatar
BTO BTO is offline
BTO is on a distinguished road
BTO BTO is offline
BTO's Avatar
These 4.0L are noisy. Using 0w-20 oil does not help. My Tacoma has essentially the same engine but is spec for 5w-30 and is much quieter.
BTO is offline   Reply With QuoteReply With Quote
Old 01-02-2025, 02:47 PM #12
thatoneguy's Avatar
thatoneguy thatoneguy is offline
thatoneguy is a jewel in the rough thatoneguy is a jewel in the rough thatoneguy is a jewel in the rough thatoneguy is a jewel in the rough
thatoneguy's Avatar
03!
They're old. But they're proven to work. We've got a member here with like 360k+ miles on a 4.0L with 10k oil change intervals. Everything but the rear main seal is overbuilt.
2023 TRD Offroad Premium, want to buy 2010+ TRD PRO exhaust, SLC area.
Former: 1987 SR5 w/ SAS, 1999 Limited w/ e-locker
thatoneguy is offline   Reply With QuoteReply With Quote
Old 01-02-2025, 04:38 PM #13
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Sounds like a diesel.
Howls, whines, clicks, taps, roars.
Hopefully for 400,000 miles.
2010 Trail - 146k mi - KDSS - Classic Silver Metallic - Bilstein 5100s - Tires: Michelin X-LT A/S 36psi - Oil: M1 EP 5W/30 - Diffs and T/C: Delvac 75W-90 Synthetic - Toyota WS ATF - ScanGauge - Viofo dashcam - Husky Weatherbeaters - Plasti Dip wheels and chrome delete - Wheel Center Caps delete - Roof Rack Cross Bars delete - Cargo Tray divider delete
1000MPH is offline   Reply With QuoteReply With Quote
Old 01-30-2025, 03:45 AM #14
Thanks man, ya I'm getting used to it. It's partly that I had a 2nd gen 22re with flowmaster 40 so the only time I really heard the noises of that thing (other than every time I drove up a hill) was when I was under the hood or when something was really wrong.
I've spent some time using an endo scope and got a look inside the timing chain cover. The chain and tensioner look well brand new, and from what I can see the guides are intact and in good shape. I am pretty sure one sound is the whine that other users have experienced from the timing chain idler gear which starts to fail and makes the engine sound like it's super charged.
The other sounds I think are mostly the noise of this Dual VVTI 4.0 beast.
The metal I'm waiting for blackstones response on and I'm going to do another oil change and see what the magnetic plug picks up and if anything else is in oil.
I think the metal flakes may either be from the failing TC idler gear or from what I could see inside the TC cover is cast and there's a lot of imperfections on surfaces just like you can see on the outside of the engine. I suspect it's possible some of these could loosen up and come off.
I also think I've narrowed down another sound I notice particularly when I put it in gear. And that is my idler pulleys on the v belt are starting to go. Definitely not rolling super smoothly. Not terrible, but I need to pull the belt again and put in gear and see if the sounds there. I'm really hoping that's it and not some engine internals.
Old 01-30-2025, 01:45 PM #15
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
Originally Posted by thatoneguy View Post
03!
The Single VVTi 1GRFE used from 2003-2009, and to 2015 in the Tacoma, is significantly different than the Dual VVTi 1GRFE used in 2010-2024 5th gen 4Runners, and 2010 and up FJ Cruisers.
Different block, crankshaft, cylinder heads, and intake and exhaust, etc, etc. It's so different, that I think Toyota should have changed the model designation of the engine more significantly than they did.
02SE is offline   Reply With QuoteReply With Quote
chain , oil , pump , time , timing
How big of concern do you think this is? MrGainzz General Discussions 7 01-09-2018 04:05 PM
Cause for concern?? jonesmw10 4th Gen T4Rs 11 02-21-2015 01:15 PM
LBJ - Cause for Concern? Robb235 3rd gen T4Rs 14 10-10-2013 02:37 PM
Is this a cause for concern? Ilovesnow 4th Gen T4Rs 4 01-28-2010 03:00 PM
A/C Fan concern MikesToy Problems & Warranty Issues 1 09-15-2008 08:01 AM
