Old 12-16-2024, 05:07 PM #1
Jeff_DML Jeff_DML is offline
Jeff_DML will become famous soon enough Jeff_DML will become famous soon enough
fuel light coming on earler?
My 2018 has 85k miles and it seems like the fuel light comes on earlier nowadays. For example, When it came on today and I filled it up with a bit more than 18 gallons, so almost 5 gallons left. I know the 3.5g is approximate but I thought it use to be pretty close when it was newer. The reason I care is use when I am off-roading/road trips for reference on how bad I need to fill up.
Anybody notice the same thing and fix it somehow? guessing it just measures the level in the tank but maybe fuel filter or something.
thanks
2018 SR5P+3rd row, 285 KO2, 5100+Dobinsons 300/505
Jeff_DML is offline   Reply With QuoteReply With Quote
Old 12-16-2024, 08:44 PM #2
hoobhoob's Avatar
hoobhoob hoobhoob is offline
hoobhoob is on a distinguished road
hoobhoob's Avatar
Did you perhaps crush part of your tank skid plate and indent your tank reducing capacity?
hoobhoob is offline   Reply With QuoteReply With Quote
Old 12-16-2024, 09:38 PM #3
Good point, I do have some minor dents but will look if anything new.
Old 12-17-2024, 12:20 PM #4
One decent sized one but doesnt seem gallon sized dent though. A few minor ones in the other pic. I am not sure how the sensor works so maybe the bigger one messes with it enough. It does come on and off maybe more often.
thanks
fuel light coming on earler?-pxl_20241217_160240896-jpg  fuel light coming on earler?-pxl_20241217_160423332-jpg
Old 12-17-2024, 12:25 PM #5
Fuel tank is plastic right? I wonder if I take off the skid and pound out the dent if the fuel tank would go back to original form.
Old 12-17-2024, 12:50 PM #6
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
I’ve got logs. The only time my light comes on early is when I’m on steep hills. 18.18 seems to be the lowest amount I’ve pumped back in when the light has come on, and that could be other factors. A couple times between 19 and 19.5 but mostly above 19.6gal.
I’ve had to pound out dents on my fuel tank skid plate several times but its never dented the tank. One of the bolts is difficult to get to unless you lift the rear onto stands.
The silver fuel tank skid plate bolts are 77644-60020 12mm
2010 Trail - 146k mi - KDSS - Classic Silver Metallic - Bilstein 5100s - Tires: Michelin X-LT A/S 36psi - Oil: M1 EP 5W/30 - Diffs and T/C: Delvac 75W-90 Synthetic - Toyota WS ATF - ScanGauge - Viofo dashcam - Husky Weatherbeaters - Plasti Dip wheels and chrome delete - Wheel Center Caps delete - Roof Rack Cross Bars delete - Cargo Tray divider delete
1000MPH is offline   Reply With QuoteReply With Quote
Old 12-17-2024, 11:26 PM #7
5thToy 5thToy is online now
5thToy is just really nice 5thToy is just really nice 5thToy is just really nice 5thToy is just really nice
Does the fuel light trigger based on current rolling average fuel economy to determine when to light up based on a fixed number of miles to empty?
In other words, if your current rolling average is unusually low due to say towing, extended mountain or off-road driving that average suggests needing more gas in the tank to still be able to travel say 60 fixed miles to empty.
Just a thought.
5thToy is online now   Reply With QuoteReply With Quote
Old 12-17-2024, 11:34 PM #8
Just a thought.
Owners manual says it comes on when there are approximately 3.5 gallons left
Old 12-17-2024, 11:36 PM #9
If that's the case then the only other thing that comes to mind is the sending unit.
Old 12-17-2024, 11:50 PM #10
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Just a thought.
It is a float. No logic to measure your driving history.
fkheath is offline   Reply With QuoteReply With Quote
Old 12-18-2024, 12:50 AM #11
1000MPH's Avatar
1000MPH's Avatar
Ive checked my range when the light comes on and it varies between 20 and 30 miles, iirc.
Old 12-18-2024, 02:48 AM #12
likorplf likorplf is offline
likorplf is on a distinguished road
The fuel gauge works by measuring the fuel level through a sending unit inside the tank. Over time, this unit can wear out or get clogged, leading to inaccurate readings. This could be the primary culprit if the fuel light is coming on earlier than expected.
likorplf is offline   Reply With QuoteReply With Quote
Old 12-27-2024, 10:40 PM #13
Ezlife45 Ezlife45 is offline
Ezlife45 will become famous soon enough
I just know that my low fuel light typically comes on when the DTE or range says 20 miles to empty. I drive mostly hwy at about 21 mpg typically
Ezlife45 is offline   Reply With QuoteReply With Quote
fuel , gallons , guessing , light , trips
fuel coming from the frame rail piggy 3rd gen T4Rs 17 11-02-2023 01:30 AM
Help. Smell of fuel coming from exhaust drei4runner29 3rd gen T4Rs 24 10-15-2023 11:52 AM
Strange noise coming from fuel pump??? Toskabg 5th gen T4Rs 3 09-09-2020 12:00 AM
Position of low fuel light pin on fuel tank connector eurasiaoverland 3rd gen T4Rs 8 10-15-2019 03:45 PM
VSC Off light NOT coming on with CDL and 4LO? dkyleb 4th Gen T4Rs 7 04-06-2016 01:56 PM
