Old 12-29-2024, 04:48 PM #1
sunnah sunnah is offline
sunnah is on a distinguished road
Question P0705 Range Sensor - Neutral Start
2017 4runner 26909mi
Code: P0705
Toyota part number: 84540-35060
Is the DYI fairly simple? I do not have a lift. I cannot find any specific videos/tutorials that I can follow. The ones I have seen were not that great and each one had difficulty getting the old one out.
Any advice?
sunnah is offline   Reply With QuoteReply With Quote
Old 12-29-2024, 11:52 PM #2
CutthroatSlam CutthroatSlam is offline
CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of
Code: P0705
Any advice?
Your part link showed a neutral back-up safety switch. They are not hard to remove and install. Looks like one bolt and it slides off the shift shaft.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 12-30-2024, 07:15 AM #3
djeepin djeepin is offline
djeepin will become famous soon enough
first use wire brush and clean rust from shaft. then spray with penetrating fluid.
if it is not sliding out easy, carefully cut slot in it with tool not very powerful tool
and open it up with flat screwdriver. no force applied here. remember if you damage shaft, transmission is gone. use plenty of grease on assembly and dielectric grease on wire plug. wires corrosion also very common.
djeepin is offline   Reply With QuoteReply With Quote
Old 12-30-2024, 01:05 PM #4
Found two videos on removing the neutral back-up safety switch. In both cases, they had to pry it off, basically mangling the old switch. One guy broke the inner sleeve up using a chisel and hammer, then hit the shaft with a welding torch. Not so sure I would do that as it would compromise any seal on the shaft. In both cases it was corroded onto the shaft. So soaking it with penetrating oil is a good idea.
Once the switch comes off, the new one goes on rather easy. Slide it over the shaft, then tighten the bolt.
Old 12-30-2024, 09:38 PM #5
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Look up a post by Jeremy556 on 3/16/21 on the neutral safety sw. He has pics, part # and description on how to remove the connector and change out the sw. You can also search on neutral safety sw. There are a couple of threads on this subject. Cars from the North and East seem to hav this issue due to Winter salt used on the roads.
Old 12-31-2024, 12:38 AM #6
Here’s the ugliest DIY video that I could find on this:
https://youtu.be/6_cq99fCFUg?si=q4nlfOm4O-eFEzB-
Old 12-31-2024, 09:05 PM #7
RC57 RC57 is offline
RC57 is on a distinguished road
Would it benefit for me to take it off my 2024 now, while it's new, and apply some anti-sieze?
2024 Ltd 4x4
RC57 is offline   Reply With QuoteReply With Quote
Old 01-01-2025, 01:21 AM #8
Yes, If you live in the rust belt. Not so much if you live in the southwest.
Old 01-01-2025, 03:01 PM #9
flyrv9's Avatar
flyrv9's Avatar
Yes it would help I think. There is a thread where the switch was removed and taken apart, cleaned and resealed while waiting for a new part. Turns out these switches are not sealed or protected very well - hence all these failures.
neutral , p0705 , range , sensor , start
P0705 Error and bad Neutral Sensor Switch hkazmi 5th gen T4Rs 9 06-02-2022 08:10 PM
NSS/Range Selector Switch - P0705 code kenwilliams0803 5th gen T4Rs 16 04-04-2022 11:28 PM
Neutral safety switch/range sensor - part #s and removal IFD933 5th gen T4Rs 2 12-17-2021 07:51 AM
Transmission range sensor (neutral safety switch) KPZVR4 4th Gen T4Rs 2 03-10-2018 06:33 PM
Dealer valet shifted into low range without trans in neutral MTwEeZi 3rd gen T4Rs 21 10-24-2015 08:46 AM
