Old 12-31-2024, 12:11 PM #1
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
2018 4Runner MGM roof paint failing
The paint on the roof of my '18 is failing. For context, I live in Florida and my 4R is parked outside so it gets a lot of sun, but I try to wax at least twice a year. Noticed the paint while I was putting my cargo carrier up on the roof rack for a recent road trip. The paint under the cross bars still looks to be in good condition. I've seen threads about issues with the white paint, but this is pretty disappointing for a car that's just 6 years old. I know, the quality of the paints isn't as good these days and I should be happy I even got 6 years out of it. On the plus side it's just the roof, the hood and other panels look like new. Most likely I'll get one of the 3 stage paint kits and tackle it myself when the time comes. Anyone else having this problem?
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 12-31-2024, 03:16 PM #2
Muzzle of Bees Muzzle of Bees is offline
Muzzle of Bees will become famous soon enough
It looks like a failure from the factory paint process. Have a paint shop investigate for you and go from there. I’d think it would still under warranty.
2016 TEP
Muzzle of Bees is offline   Reply With QuoteReply With Quote
Old 12-31-2024, 04:35 PM #3
Grug556's Avatar
Grug556 Grug556 is offline
Grug556 is a jewel in the rough Grug556 is a jewel in the rough Grug556 is a jewel in the rough
Grug556's Avatar
Looks like initial stages of delamination of the clear top coat. The striations in the film will eventually rupture causing delamination from the base coat. This coating is not fixable with that amount of cracking in it.
Likely the result of an improperly qualified new supplier in a enviro friendly low voc junk paint.. give me lead... give me cadmium..give me chrome.. solvent based please...with heavy metals. The greeny shit is just that..shit.
Often times OEMs based coating choices on accelerated weathering type lab testings for qualification processes, perhaps a weatherometer for SAE J2527 or similar accelerated xenon arc testing and or with cyclic corrosion component in addition for even more aggressive testing. Problem with this is there is no actual correlation between accelerated and real world exposure, to many variables including regional disparities in industrial pollution and or UV exposure/intensity.
See if Toyota will help pay or it. Or strip it and paint a clean on it again. Although I would be abit leery on the base coat as to how damaged it is as well. Likely they are comparable systems. Likely has base type primer, pearl type coating in grey with high gloss low VOC clear on top..
Grug556 is offline   Reply With QuoteReply With Quote
Old 01-03-2025, 12:56 AM #4
Sonoran_Desert Sonoran_Desert is offline
Real Name: Jo
Sonoran_Desert will become famous soon enough
Real Name: Jo
Sorry about your roof. Even if you are past warranty, I would get this to dealer and see what they say.
Sonoran_Desert is offline   Reply With QuoteReply With Quote
failing , good , paint , roof , years
Does a failing CV sound like failing bearing? gaber6 4th Gen T4Rs 8 07-22-2020 02:34 PM
BEST touch-up paint distributor for Blizzard Pearl 2018? Anonymous4Runner 5th gen T4Rs 7 07-02-2020 01:42 AM
Any way to differentiate between failing double cardan joint or a failing rear most u Anthrax 3rd gen T4Rs 29 04-08-2019 09:49 PM
2018 SR5 issue with paint on lift gate trim possible defect? JAXJeremy Problems & Warranty Issues 4 11-20-2018 12:51 PM
