Old 12-31-2024, 08:55 PM #1
RC57 RC57 is offline
RC57 is on a distinguished road
5th Gen LE 4WD vs 4th Gen Failure
My dad had a 4th gen Ltd 4wd for occasional retrieval of off-field glider landings. The 4wd got used infrequently. It would often malfunction from lack of use, with the servo motors seizing. This appears to be a common malady for that 4th gen. The official Toyota repair required pulling the transfer case and replacing the servo unit. More adept owners were able to do a servo unit teardown/cleanup in a few hours with no parts required. Simply running the 4WD through it's paces once a month helped avoid this potentially expensive issue.
Does the 5th gen Ltd 4WD have this same vulnerability? I bought one for occasional use in snow when I visit up north. Will it start malfunctioning if I don't "exercise" the 4WD regularly? It's a many mile drive from where I live to a dirt road where I can lock the center diff and put it in low.
My 3rd gen Ltd didn't have this problem.
2024 Ltd 4x4
RC57 is offline   Reply With QuoteReply With Quote
Old 12-31-2024, 09:06 PM #2
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
The 5th gen Limited is full-time 4wd. It is ALWAYS in 4wd. So no you won't have issues shifting from 2wd to 4wd, as you can't.
You COULD eventually have issues with the ability to shift in and out of 4low, if you don't exercise that occasionally.
02SE is offline   Reply With QuoteReply With Quote
Old 01-01-2025, 08:32 PM #3
My area many decades ago had plenty of dirt roads. No more. Went into the boonies and found a lime rock road. Locked and unlocked the center diff multiple times. Shifted multiple times into Lo likewise. Unless I hear there aren't servo motors prone to seizing due to rust, I'll probably do this monthly.
2024 Ltd 4x4
Old 01-02-2025, 11:55 AM #4
thatoneguy's Avatar
thatoneguy thatoneguy is offline
thatoneguy is a jewel in the rough thatoneguy is a jewel in the rough thatoneguy is a jewel in the rough thatoneguy is a jewel in the rough
thatoneguy's Avatar
That being said, all other 5th gens with their part-time 4WD system do still have this same vulnerability, and owners of those remain suggested to through their hunk of junk in 4WD once a month or so to avoid the same annoying/costly fate.
And even if you have the manual transfer case lever, best to let the ADD system run its paces.
2023 TRD Offroad Premium, want to buy 2010+ TRD PRO exhaust, SLC area.
Former: 1987 SR5 w/ SAS, 1999 Limited w/ e-locker
thatoneguy is offline   Reply With QuoteReply With Quote
Old 01-02-2025, 04:20 PM #5
Whippersnapper02's Avatar
Just find a straight road and lock it into 4wd for a while about once a month.
4th , 4wd , 5th , gen , servo
O2 failure help ccool91 4th Gen T4Rs 4 04-07-2017 01:43 AM
AIP failure Fourrunfunnin 4th Gen T4Rs 6 05-18-2016 10:45 PM
I'm a DIY Failure! Spiggie 4th Gen T4Rs 12 08-13-2011 12:46 PM
Yet ANOTHER V6 Failure!!!!!!!! LandRvr Convert 4th Gen T4Rs 1 01-02-2011 10:42 PM
JBL CD Failure <<<< 4th Gen T4Rs 2 12-24-2007 12:45 AM
