Originally Posted by 02SE
The 5th gen Limited is full-time 4wd. It is ALWAYS in 4wd. So no you won't have issues shifting from 2wd to 4wd, as you can't.
You COULD eventually have issues with the ability to shift in and out of 4low, if you don't exercise that occasionally.
That being said, all other 5th gens with their part-time 4WD system do still have this same vulnerability, and owners of those remain suggested to through their hunk of junk in 4WD once a month or so to avoid the same annoying/costly fate.
And even if you have the manual transfer case lever, best to let the ADD system run its paces.
